Using PX with passive sub/amp
I am using two DB Technologies 415s as tops (powered speakers). For a a DJ party we rented a Behringer passive sub/bass amp with an amplifier -- all we could find in our rural area. While running Setup Wizard with two tops and the "sub" I could not get past the level adjustment because of no sound from the sub. Is it impossible to use a passive sub with the PX? The amp had 1/4 inch "passive" and "active" inputs as well as DI xlr input.
Don't expect a lot out of that sub... set an HPF of minimum 45 hz BW18.. and I'd set a 100 hz LR24 ...
