Looking For Some Guidance For PA+
Here is my set up:
2 EAW JF 500C 3 way cabinets. Mids and highs are still original RCF components. Lows have been changed out to B&C 15PZB 40 woofers. Running tri amp with no subs. These lows actually hit pretty good without subs. Lows are running on bridged Crown XS1200. Mids are running on bridged QSC RMX1450. Highs are running on QSC RMX850.
I have set up the gain structure on the Drive Rack and the amps.
Need some advice on setting the crossover points. EAW says 250 and 1.8. What type and slope would you recommend?
Also need some advice on setting the PEQ. Where do you find the info to set that? IE band, freq, etc.
Any help would be greatly appreciated.
Thx,
Mike
Thx,
Mike
It's very easy to try different slopes with ANY of the driveracks, so you can see what the different slopes sound like to you...remember, you can also overlap, try leaving a bit of a space between frequencies where interactions can cause problems in the crossover region.
gadget
Thx, Mike
There is a possibility that you might get a response if you fire an email or phone call to EAW, or you might get lucky if you post on the PSW and ask for settings...
It looks like these were discontinued before there were DSPs
http://www.eaw.com/info/EAW/Loudspeaker ... /JF500.pdf
