ndoor auto eq questions
In the faq section under the indoor auto eq methed, the mic in one photo is at a slight angle pointed toward the ground at a tilted board, in the second photo the mic is at a perfect 90 deg to the cement floor with no board, Im confused as to what the difference is and as to why your not aiming the mic directly at the speaker between the woofer and horn, when I ran a pass outside I pointed my mic directly at the speaker, not saying it is right just wondering what the benifit is to pointing it at the floor like that and if you have carpet do you still aim it at the floor in the same way? Thanks!
The current 'best bang for the buck' (indoors) has been to place the tops laid on their sides (as in the last photo) tilt it toward the mic slightly..and place them both on a soft surface with the mic aimed at the speaker...
