Need Help - DriveRack PA+ Crossover settings for new setup.
Hello,
My system is the following:
2 x JBL, MRX515 connected in stereo to QSC RMX2450 amplifier.
1 x Oberton, SB118 (18", 800W RMS @ 8 Ohm) Sub connected to Uniqaudio PA1800 amplifier (an exact copy of EV P2000) bridged mono - 1200W @ 8 Ohm.
Oberton, SB118 Sub Specifications:
TYPE: 18" bass box
APPLICATION: Subwoofer
Frequency Response: 40 – 200 Hz ( -10 dB)
Power Capacity AES ( low, mid, high): 1000 W
Program Power ( low, mid, high): 2000 W
Peak Power ( low, mid, high): 4000 W
Sensitivity 1W/1m: 98 dB
Max. SPL peak: 134 dB
COMPONENTS:
Low Frequency Driver: OBERTON, 18XB800
Impedance: 8 Ohm
Connectors: 2 x Neutrickâ„¢ NL 4
Dimensions (H x W x D): 820 x 630 x 620 mm
Weight: SB118 - 53 kg
Oberton, 18XB800 speaker specifications you can find at the below link:
Specifications
Mixer: Reloop, RMX-40 USB
Source: Desktop PC with M-Audio, Audiophile 2496 PCI sound card.
Processor: DBX, DriveRack PA+
All in the Setup Wizzard is set as it should be - the sub and the sub amp are set to Custom.
Please advise on what crossover points, LPF, HPF and should (Linquitz-Riley) 24dB per octave slopes be used or other for the JBLs and the sub.
Any help will be much appreciated.
Thank you in advance.
TYPE: 18" bass box
COMPONENTS:
Impedance: 8 Ohm
Specifications
HPF 45hz BW18
LPF 100hz LR24for the subs and
HPF 100hz for the tops...
Read the "starts here" thread,
and check out the FAQ's
Here:
viewforum.php?f=60
Thank you very much for the fast response and your suggestions. That's what I needed before the first tests.
