setting EVX 18b and Jbl Frequencies
Hello,
I already sent a message asking help with setting my system frequencies with some scoop speakers. I use the system for a local band here in Belize. Here are the system specs:
Mixer--Yamaha MG32/14FX
Crossover---Drive Rack 260
2 PV CS-800 series amps-(highs)
2 QsC PLX 3202--(mid)
2 QSC PLX 3402---(lows)
8 scoop bass speakers with EVX 18b Inside
4 top boxes (MID& HIGHS)
each box have 2 JBL 2206 12" speakers and a JbL 2447h High driver.
I appreciate your suggestions.
Thanks: rol
Thanks: rol
Based on that, to start, I think I'd go ...
Subs - 35hz, BW18
- 100hz, LR24
Mids - 100hz, LR24
- 750hz, LR24
Highs - 750hz, LR24
- 16Khz, BW6
I will try this this setting and see how it works.
The typical xo point between 2206 and 2447 is 1.1K - 1.3K...but I have had good luck running a xo point as low as 900 - 950...the 2447 is only rated down to 800
Dennis
The sheet I saw was 150w @ 1K, 100W @ 500hz. I guess it all depend how hot they will be run and how much protection he wants.
Do I need to use the polarity phase for my system?
However , a 4" voice coil JBL (hell even a 3" voice coil) are pretty bullet proof, HOWEVER...the longevity of the driver is brought into question the lower you go, frequency wise...
The main reason is the material that serves as the surround...it is usually the same as the dome.. titanium or aluminum, or in the REALLY expensive drivers...berillium.
Run with Dennis's suggestions.
