How do I select proper crossover points and slopes
I have some monitors that are very nice, they are Biamped, They all have Two twelve inch speakers and one horn, the dirvers are all P audio, the horns are DDS and If I remeber right they work well down to 1.2 K, they are 2 inch horns, The drives on the horns are rated to work down to 800 hz,
I was using driveracks as xovers, but to get 8 mixes, it was better for me to buy Crown XTI's and use the DSP ( I hope so)
I have 4 k Xti on the lows and 1 Ks on the highs
I have used Gadgets 121db monitor before and got them to 119 db before I gave up
Very loud and clean.
I am looking to smooth them out a bit with the Dsp on the crowns, and they sound better (at a low volume) with a butterworth at 6 or 12 db of slope, but I get better cutoff when I use LR at 24 db of slope. I am worried about things getting by and taking out the drivers with the slope at 6 db .
suggestions
Suggestions?
suggestions
Suggestions?
http://en.wikipedia.org/wiki/Linkwitz%E ... ley_filter
Dennis
You'll also find that using the HPF and setting it up between 130 and 150hz will cut a lot of the stage rumble and din.
The monitors I have are some Clair/Mcbride and where used by the likes of Garth Brooks and Martina Mc, to name a few.
I was beginning to over lap the xover points when i was using the LR 24 filter as I was getting such a suck out near the xover Freq, at that point it was, 1.33 Khz, it seemed to be very smooth there with the DBX units but so much with the XTI,
I am just beginning to try some things but with all the expertise on here, I see no reason to reinvent the wheel and felt you would give me some good direction and I thank you all for that,. Here is a peicture of these monsters,
I will be working on them today and see what I can do with them, I will let you know
When beginning the alignment, you will see quite a valley at the xo point. The closer you get to time alignment, the closer you get to eliminating the valley but you may have difficulty achieving "smooth and flat". Perhaps at this point, a tiny amount of overlap would be your friend but I am talking only 2 to 4Hz. You can also deploy some PEQ filters to smooth things out but concentrate more on cuts than boosts.
Dennis
The method he speaks of is a null method...you would need a frequency generator that can play the exact frequency of the crossover point. Then it's a matter of reversing the polarity of the horn (either would do but there is only one set of leads to reverse) now you play the frequency, and sweep the delay and listen for the greatest null. This then would be the closest you'll be able to get without measurement tools.
What we have done here is play the tone at the crossover frequency and reverse the polarity of one of the waves... where they are MOST out of phase is where the two cancel each other out. Don't expect total cancellation because overtones and harmonics are involved... just look for the greatest dip in the primary frequency.
Put things back to normal and there you have it...
You might want to try several different slopes while your at it and mark down the delay for each. When overlapping, the BW filters are the most musical, and 24 and 48 slopes are best. BW 18 is a good choice for HPF's.
If your looking to tailor/LPF the high end, LR6 or the like offer minimal phase shift and artifacts. Those filter types just don't make very good xover filters because there iks just too much interaction in the crossover region.
http://www.ringbell.co.uk/software/audio.htm
to inject the signal...
Interesting....I bet I could find an iPhone app. Or maybe I already have one.
Thoughts?
g
Appears to be an allpass filter with limited features...it automatically sets itself to the upper frequency of a pass band offering no user control of that function.
In the GUI double click on the 1,2,3... etc. and an output polarity/phase drop down appears...
Dennis
