Need processor settings for EAW660 speakers
Need processor settings for EAW AS660 3-way mains speakers. I'm guessing this would be Bi-amp? EAW website did not provide a lot of info on this. Thanks for your help. Need Cossover settings, PEQ, Delay times if any.... sub-h Synth...
(Everything in mono)
-I have 4 EAW AS660 house speakers.
-I have 2 OAP FH118 horn-loaded subwoofers (22" trckpack version?)
-I have 2 driverack 260's
-Soundcraft GB4-32 FOH mixer
-QSC RMX850 power amp for monitors and front fills (front fill speakers are EAW JF60)
-QSC RMX1450 power amp for hi-mid mains
-QSC RMX2450 power amp for low mains and subs
I think that is it. I'm using preset 9 I think in the DR 260. Muti-zone I think is fine for this set up.
PS- I would like to run aux fed subs with this set up also.
Jon
Jon
See here:
http://www.eaw.com/info/EAW/Processor_S ... S_rev2.pdf
Page 5
AS660e
Tri-amp
Bi-amp
Including info for tri-amping with a subwoofer...
4 parametrics on the LF
3 parametrics on the MF and HF
Delay
xovers it's all there...
Now, as far as Aux fed subs go...
If you haven't yet, get the GUI and do the setup with it... it's FAR easier, you can only use one 260 at a time on a serial port... there are ways with other systems but I digress..
you could actually do the processing with one 260 and leave the other for monitor duty?
Forget presets... this is a job for the Wizard...
Set up your 2 inserts
select custom bi-amp tops and stereo subs (2X6)
Next, you can load your amps or custom... it really makes no real difference
select the path you like or leave the default.. that's what I do..
Now, Load the preset, and then hit the [config] button
When in the config mode you will need to use the [shift] and [Ctrl] keys to get the full benefit... but highlight what you want to change(left click) (like the crossover) then right click and from the dropdown menu choose the crossover you want (1X3)
You'll also want to unlink the input modules... right click highlight, left click unlink
you'll also want to do the same for the PEQ's and limiters and delays after the xover, and set up the xover/bandpass for the subs in the same fashion...
You can redistribute the deal as necessary
the right input would then be usable for the aux fed sub input
You can also name the individual outputs and the preset name
Note: the pre delay is great for backing up the FOH to the loudest point on the stage (like the drum monitor) If you fly the mains it's got plenty of delay to align with the subs...
***Note****
The FH118 subs are specifically designed to be used in a minimum GROUP(BLOCK) of 4 units!!!! 8 would be needed to produce a true 40hz sub array...
(I have OAP as well)
Moderator...
-Jon
-Jon
By graph, do you mean the chart that lists all the x-over and PEQ settings?
Are you unsure where these numbers plug in to the 260?
All the numbers, or just some of them?
If you are feeling intimidated by this, don't be. It is really quite simple.
Go custom, bi-amp & custom subs and select the RMX amps you have. Set up the 260 for Hi (cab mid / hi), Mid (cab low), & Low (subs).
Starting at the top.
The wizard gives a default +2.6db boost on the x-over gain on the high amp. Not sure if that means that matches the amps outputs or what, but maybe. So open up the x-over and increase the x-over gain of the mids (cab low) +1db. (per chart) Set the Hi gain to +2.6db.
Open the Mid OUTPUT Delay Module(s). Add 1.1ms of delay (select "seconds).
Open the x-over module. In the Mid filter (BLUE) set the Hi Pass (HPF) to 35hz (because it's listed on the chart), but since you are using subs change it to 125hz (I like 100hz, but it is EAW's recommendation).
Set the Hi Slope to L-R 24.
Still in mid filter (blue) set the Lo Pass (LPF) to 243hz.
Set the Lo Slope to BW 24.
Open the Hi output PEQ module(s).
Select "Bell" as the type, because you don't have any shelf requirements listed.
PEQ module - "ON"
There are filters listed at 50hz and 76.5hz, but since you are crossed at 100hz / 125hz, it would be moot to put them in. (If you ever use the 660's by themselves, you can set up a different preset slot with these PEQ's.)
Band 3 Fc (blue) left click on the frequency numbers to the right of the bar slide and type in the frequency (265) (Note: for number above 999, such as 1.3K, you must type 1300) (Note: the 260 will change the value to the nearest value allowed. Example: you enter 657. The 260 changes to 648.)
Q - Left click on numbers and type in the value shown (3)
Level - Enter or slide to -6db
Ingore the bandwidth data on the chart, it is another way of defining the value of "Q", and not used in the 260.
Follow this proccess to complete the other x-over filter and PEQ data entries.
I bet Gadget can give you some good numbers for your OAP's.
See, really easy.
Teach a man to fish...
Give a man a pole...
So unlike you. :shock: :?
I know more than I did after talking with you. I will look at the file you send me and compare it with the chart on EAW website to see better understanding. How will I go about loading this file that you send me and putting it in the driveware and will this still allow me to do aux fed subs? Thanks for your time and help and sending the file.
-Jon
-Jon
-Jon
Also, I have peavey 15m 15 floor monitors. Would I need to set a crossover or just a filter for the monitors? And will the monitors need PEQ (and what PEQ frequencies) or only auto-EQ? Any auto-leveling for monitors.....?
PS-Any recommended compressor settings or sub-harmonic settings for this particular set up (house speakers),limiters or compression for house speakers or monitors? Or should I just start with a 2:1 ratio for compression and use my ears?
-Jon
If the mid range were assumed to be -0- the lows would be +5 and the horns -3 for the tops. but... according to the axial sensitivity they are
106dB 1 meter 1 watt LF
109 dB MF
109 dB HF
which is +3 , -0-, and -0-
I don't know.. I guess I'd go by the processor settings...
Anyway, if you take the various amps gain differential (the 850 is 30dB the 1450 is 32dB and the 2450 is 34dB) That's a
-0-, 2dB and 4dB difference ... or in the example above -2, -0- and +2... so theoretically... the tops would be:
Lows +3 the mids -0- and the horns -2 for the crossover gains...
The subs are only 99 dB efficient, but I don't think adding 7dB is gonna cut it, especially with the LACK of subs you have...I assume they are together.. I'd suggest that you do so if you haven't already...
Or, as I said you can go to the "Start here thread and use the method there to do the job...
For the floor monitors follow this tutorial:
viewtopic.php?f=60&t=2410&p=13144#p13144
