Sub Output Level
edited February 2011 in DriveRack PX
After running all wizards (setup, eq, AFS), using the QSC K12 & Ksub presets, my system sounds pretty good, but I want more out of the mono sub. On the DRPX output meters, the sub level is always 2 or 3 lights lower than the L/R mains. What parameter do I adjust to increase the mono sub output on the DRPX? Thanks.
Mackie CFX mkii mixer
dbx Driverack PX
QSC K12 mains L/R
QSC Ksub mono sub
QSC K10 monitors (2)
  • The meter ballistics are not the best on those units...If you want more out of the subs turn up the subs crossover gain... but if it's just a meter thing and things are working ok... don't worry about the meter.... BTW that's all in the digital realm, and signal to noise isn't the same as in analog gear...
    gadget
