Peavey and Carvin setup assistance
Hello guys, just purchased a used Driverack PA and am wondering about settings. Looks like the previous owner put in some custom settings for speakers/amps not in the original configuration so I really don't trust these. I''ve set my gain structure as directed. It's for a 4 peice rock band who will be playing small clubs. Any suggestions concerning wizard settings, whether to chain the speakers to get 4 ohms, buy more amps, etc. I've been messing around quite a bit with the driverack PA but would like to hear from he experts. Any help would be greatly appreciated!
Thanks!
I also need to power four 8 Ohm monitors.
Speakers
2 Carvin 832 full range tops
400W Continuous
100 dB SPL 1 Watt @ 1 meter
8 Ohm
http://www.carvinguitars.com/cartech/crg/manuals/832-v1.pdf
2 Peavey 118 sub HC (I converted 1/4 to speakon)
Single 18" Black Widow
350W Continuous
8 Ohm
http://www.peavey.com/media/pdf/manuals/118subhc.pdf
Amps
QSC RMX 850
http://www.qscaudio.com/pdfs/manuals/RMX_User_Manual.pdf
Mackie FR 1400
http://www.mackie.com/pdf/m1400_m1400i_om.pdf
Thanks!
Speakers
400W Continuous
8 Ohm
350W Continuous
8 Ohm
Amps
QSC RMX 850
Mackie FR 1400
Ya, your terribly under powered... and those really aren't subs... more a low mid cab...I would bridge both amps...Set a Hipass of 45hz BW18 maybe even 50hz... Set a crossover of 118hz LR24 for tops to subs same for both... I think those are 15",6"and horn right? those cabs won't really handle what they say, and the crossovers are very delicate and mounted terribly...
I think I need to shop for different subs if these won't handle the job. These said they go down to 42 Hz, how far should they go down? Thank you for all your time!
For Dj work, with heavily compressed music, the speakers are best served using only the "program" level of power, since the duty cycle of the amp is much higher, and heating of the voice coils is more likely to happen.
Nevertheless, the amp can only put out 1260 watts bridged mono... and if there were 2, 8 ohm speakers hooked up to this amp in bridged mode, each speaker would only get 1/2 that power or 630 watts... well UNDER the 700 watt program rating...got it
Now, since you have been away, as I said, great strides have been made and we have provided a treasure trove of info for you to catch up in the getting started:
viewtopic.php?f=61&t=959
and FAQ:
viewforum.php?f=60
Threads...
I've set up the system as you suggested and I't sounding pretty darn good, I coupled the bass cabs am getting an ample amount of thump out of them. I haven't got an RTA mic yet so nothings been EQed yet. I'm moving on to the limiting next...
Thanks!
