Creating a Different 2X4 Configuration
I'm sure there is a way to do this, I could use some help on it.
I have a PA+. I want to drive a Behringer EP1500 in stereo with 2 way speakers, a summed powered mono sub, and a summed full range output for a powered monitor speaker.
If that is not possible, can I create another set of full range stereo outputs? I could feed those to a resistive combiner to drive the monitor.
Thanks!
  • Nope.... mono 2 way (tops and subs) and a mono fullrange are possible...Stereo 2X3 is possible but you can't run another output separate;y... you need a 3 channel input setup, or another crossover/Eq for that other mix...You can't do it with a 260 either...unless you want a monitor feed that is also the same as the FOH.. then you could use the mid outs as a "bandpass" filter, but as I said you won't get any "summing" just left or right input to mid output to monitor... that a 260 CAN do though...
