Beginner design help
I am an audio idiot. I work with small classroom audio (no mics typically) without any problem. Throw a mic in the works and I get myself into trouble. :? I have a larger classroom I need to design a system for with the following specs.
60' deep x 40' wide
Tiered seating
14' ceiling at the front of the room
8' ceiling at the rear of the room
2x4 standard ceiling tile ceiling
Lots of long laminate covered tables across the width of the room
I've attached a picture
Their needs are pretty basic
Lavalier mic with the option of adding a second lavalier or hand-held mic
Presentation audio from PC, DVD, etc. all switched by the projector so only 1 input to the audio system is needed. Presentation level controlled by the projector's remote. (If there's a better way to do this by all means please let me know)
Ceiling speakers???
I would like to set the mic levels and lock it down so the user cannot easily change it.
My biggest issue with mics has always been feedback way before a reasonable level is attained. So I need a processor that can tweak whatever is necessary to get the gain I need.
It needs to be easy for a complete novice like myself to setup.
Of course as always my client doesn't want to spend any more than he has to.
Can you offer suggestions on components? Thanks I appreciate the help.
60' deep x 40' wide
Tiered seating
Ceiling speakers???
http://countryman.com/store/product.asp?id=92&catid=2
It would make your life a bit easier. You will need speakers with a flat response...ceiling speakers won't play well with lavaliere mics. I have found QSC K10 to have quite a flat response and they're fairly small. Two or three of them mounted close to the ceiling at the front of the classroom should cover. One of the DBX ZonePro products could complete the system but I'm not sure how easy it will be to control a pair of lav mics with the ZonePro's virtual mixer. Gadget should be along shortly with some more ideas and answers about the ZonePro.
Dennis
Andy
I appreciate any input you can give me.
Andy
How about... what gear do you have now and what gear are you needing to buy?
Dennis
Andy
Andy
Dennis
