Subwoofer placement
should sub woofers be placed one on either side of the stage? or together in back? I hear different opinions on placement for the best sound, Just wondering what the pros do, Thanks, I realize this is a forum about the drpa but just figured I could ask this here
Truths:
1. Unless you can get the subs more than 50 feet apart then all together and in one location will provide the most even bass.
2. If you can get them centered clustered, and properly delayed to the L/R stacks you will have better sound all around.
3. If you have the subs (lots) and the amps (one per sub) you can shade the bass, you can steer the bass and you can create nulls (as on stage) ...
4. The easiest way to get what your looking for is, stack the ALL bass under one side (L/R), and use a tripod (on the other side) or fly the tops... unless you have the tools or chops to properly align a system.
5. one sub on each side will most likely cause an intense bass between the subs (right where YOU or the band are)
Dennis?
gadget
http://www.prosoundweb.com/article/a_pr ... ubwoofers/
Dennis
:? Could restate this paragraph? Put all subs on one side of DJ setup, left or right makes no difference which side? Place both Mains (tops) on the opposite side as the subs and on a Speaker Stand?
Or...are you advocating one Main on the side of the subs AND the other Main on a speaker stand on the other side where there are no subs? :roll: :?
So...if the physical setup were as follows, where x=sub, and "---"=table, and y=spkr on stand, it would look like A, B or C?
A. "Yxx---Y"
B. "xx.........Y---Y" (xx in corner, spkr on stand center stage)
C. "Y" (pole-mounted on one Sub), then table, then "Y" on spkr stand.
At the moment, I am only using one 18" subwoofer vs two subs.
Further clarification, please...for this technically challenged "old dog."
S = Sub
_______ = Table
M S M would be my personal choice for a DJ. Unless one of the mains is right next to a wall, then I'd put the sub against the wall.
sitting on the floor = 3dB of free gain
sitting on the floor and against a wall = 6dB free gain
sitting in a corner with 2 walls and the floor = 9dB of free gain
BUT there is a caveat here... the sound will not be as flat as in free space, that is to say you will notice certain frequencies will be dominant, not as bad as in a Hermoltz resonator where you have one note that is 10dB (or more) hotter than everything else, but there will be anomalies.
Centered between the speakers on the same plane as the L/R is often my go to for livesound, but I don't think the audience will see much difference than if your one sub was under one of the tops, and as Dennis said, it can help in rooms that are difficult, or that you find coverage problems with.
As I said, the answer is..."It depends"
Dennis, yes, I have been placing the York sub centered on an 8'ft banquet table with York tops at the ends. All are in the same plane, meaning fronts are in direct line of sight if you look from the end of the table to the other. This has been worked out fine. I have a second system that I use for smaller weddings and parties that has two 15" subwoofers (RCF) and obviously two Mains. I couple the subs together in the center for the extra dbs.
In both scenarios, I have been running the DRPA in "2-way, Mono Sub" program.
Premier 1...I hope the explanations above have helped you to understand placement, too.
Bill
Dennis
