640M RS-232 Strings
I need RS-232 strings for the following actions:
1. Switch Line IP 1 to OP 1
2. Switch Line IP 2 to OP 1
3. Volume Control for Line IP 1
4. Volume Control for Line IP 2
I have tried the Network Tree and string calculators method but none of these work. Anyone use these with AMX control systems?
You will need to use the 3rd party control modules or the ZonePRO String Calculator to get these strings.
You can download these items at the below link:
http://www.dbxpro.com/3rd_party_controllers.php
Modules available:
Crestron AMX String Calculator (used for other 3rd party control systems such as RTI and Extron).
Hope this helps.
