2x6 xover config??
hi.. new in the forum & new in dbx...
i've purchsed a dbx pa+ for running my sound system... but i cannot configure the xover in orther to have 6 differnet outputs.
what i need is to have 2 different outputs for the subs, coz i have 2 types of sub so i need 2 different xover cuts.
i dont know if its possible to do that... but it should, didn't it??
i would like to invert the phase to 1 of this outputs...
its possible to do that???
any help will be gratefully recieved..
THX EVERYONE
THX EVERYONE
but in the owners manual says that the pa+ can be configurated as a 2x6 xover... but i havnt found the way....
i can solve the phase problem by solding a inverted xlr... but i need to have 2 different sub xover cuts... coz i have bass reflex & folded horn subs....
if its not possible to config the pa+ as 2x6 xover... they may change the manual..
i thnik that it should be a way.. that im not finding...
Dennis
whathever...
i need to invert the polarity coz... are different label speakers and they work with different phases... by inverting the polarity i can adjust the phase so i have a sum and no cancelations.
if anyone has more info about pa+ xover config... please leave it here!!
THX AGAIN
I would make a jack panel for the amp output to invert the phase there...instead of modifying any cables.. that way any cable will work in any position...
The DRPA+ can do 2x6... just not 6 separate outputs.. it costs more money to produce that capability and dbx wanted to get the DRPA+ out at a specific price point and that was one of the limitations...
I deleted your duplicate post...
Dennis
for that job i just need a 3 way ST coz less equpment was required.. and i thought that the pa+ would be enough for after aplications...
bad luck... of course its my fault for not reading the specs... i was just asking if i could use to run all the sound...
i havnt made any mesures for the polarity... but it sounds better inverted... i think its not exactly 180... but its really near...
ill try to adjust better when i got the 260....
You can do mono three way on the left channel and use the right for a modified sub output on any of the outputs (but the hi outs have 3 Peq's to work with the others have 2) ..
i havent understood this... very well... but if i use 3 way mono... the other outputs will not be able to config, do they??
or may i send 1 sub output to a normal xover to get the cut?? its not the best solution.. but its one..??
well THX for trying to help me...!!!
Top cabs - left highs.
Sub (A) - left mids. (used as a lows output)
Sub (B) - right lows.
Time alignment is limited to 10ms per band, so you may have to physically place cabs to get everything to get it right. For example, you may need 5ms to align the tops and the front loaded subs. You may need another 10ms to align to the horn subs. That's 15ms. 5ms more than you have, so you would have to move the horn sub forward 5ft.
Thnx, Tony
