DJ New to DRPX
I borrowed a friends PX for see If it would be helpful with my DJ equipment. Venus are 200-250 people, dance music. Using 2 Behringer B215d's with Hercules RMX mixer. Will get a powered sub soon. currently using passive subs with crowne amp. reviewed links suggested in "start here". Used Setup with the 215 connected to DX using instruction from manual. (came across your forum after setup) Used custom, Streo/ no sub, level at 50 percent.. Set auto level with RTA and Mic in my basement with Mic 25 ft from speakers. auto EQ 3 and AFS 6 and Music High. System appeared to sound better than before. I have not set the SubHarmonic or Comp/Limiter yet. In the past I have used a Samson 3 way crossover with a different system (2 crowns & pyramind)
Is there a way to compare before and afterwith the PX? Since I don't have the powered sub yet does it make since to purchase the PX unit now?
If you placed the mic on a mic stand 25 feet out indoors... you got bad results compared to doing it outdoors or using the "New indoor method"...
viewtopic.php?f=60&t=953
Now, if you read the Auto eq FAQ's:
viewtopic.php?f=60&t=949
viewtopic.php?f=60&t=2346
you would have learned that reflections will skew the results.
As for before and after, it would be difficult to do with an analog crossover and the PX... even connecting the driverack changes the sound, so if you just wanted to see what it does to the 215's just eliminate the PX by plugging the input cables to the PX to the output cables, then putting the PX back into the loop. but try placing the mic on the ground on a towel about 15-25 feet out (if the speaker is on a tripod) or try outdoors away from all reflective surfaces (if you can).
gadget
P.S. I don't like the sub synth much, it can harm your speakers if your not careful...
Thanks, this forum is a gold mine of info
Thanks to all
