Limiter threshold level
I used to keep my post-crossover limiter thresholds set at 10db. This worked with the three QSC PLX amps I used since they all had the same input sensitivity (mid's the highest level and set to 0 db in the crossover).
I have recently added a QSC PL6 II to my rack replacing the PLX3402 (more mid power needed to drive my SRX722's). The input sensitivity to this amp is quite a bit higher and requires a good +5db more than the PLX3402 needed to obtain the same volume from the DR. Because of the newly acquired large spread between the mid settings in the DR crossover, I lowered the subs and highs a bit and raised the mids to +4db in gain.
All that said, do I now need to advance all the post-crossover limiter thresholds by +4db as well? (from 10db to 14db?) I am not sure if crossover gain directly relates to the limiter gain.
Thanks in advance...
Or better yet, set up the gain structure properly so that you KNOW that the amps and mixer and DR are all on the same page ...lower the amps gain below clipping and use the mixers meters to KNOW when the system has exhausted it's resources, then use the above method for the limiters to set "OOPS" protection for the speakers...your far less likely to damage the speakers with this method than to drive the system into the limiters and raise the average power of the amps that will cause voice coil heating...
As far as my last question, does increased crossover gain effect post-crossover threshold?
Dennis
Mids: Stereo @ 8ohm
Subs: Bridged Mono @ 4ohm
Dennis
