Help, Something's wrong...SRX715...SRX718s...DRPA...XTI4000s
I have the above equipment. I have set the Driverack PA to what I believe to be the right settings, but now I am wondering if I am under powering the speakers. Here is what I have it set at:
Top XTI4000 in bridge mono mode running the two top srx715s
Bottom XTI4000 in bridge mono mode running the two bottom srx718s.
The settings in the DBX are a little weird. I am actually running the DBX in stereo since the XTI4000 has a Y-mode where it combines the left and right input into a mono input, but I can still tell the DBX that the amps are run in bridge mono. So, it is set that way. The output from the amps Y into each cable that runs to the boxes. I am clipping the amps and can't get what I believe to be the volume out of my boxes. They sound great right now but I don't want to clip the amps and I think I should be getting more. The amps put out 3200w at 4-ohms. Both sets of boxes are rated at 800w/1600w/3200w Continuous/Program/Peak.
I hope that wasn't 2 confusing. Please help me get the optimal performance out of the equipment I have guys! Thank you!
George
George
Dennis
Scroll down to "Gain Structure", read all of it, and do whatever you haven't already done. Report back when that is complete. Shut off the limiter in the DR while doing gain structure.
viewtopic.php?f=61&t=959
Dennis
The 260 config for the speakers and amps you have are:
718's
HPF 30.4 hz BW18
LPF 88.4 hz BW48 gain -0-
715's
HPF 90.4 hz BW48 gain -1.7
57 (or about 1 o'clock)
Does that jive with your setup George?
