mono style setup
is this setup correct? or even possible? The outputs on the driverack PA+ are low left/mono out, and high left out.
PS... i know the picture of the driverack is not the driverack PA+
It will probably be best though to run the left ins and outs for the auto level sequence, it will also probably be a problem with the auto balance setup, but I didn't use it with mine. It's kind of a newbie feature anyway and you seem a bit more knowledgeable.. right?
Dennis
What did you use for it's creation... if I might ask...
Thanks for the help guys. Btw, where exactly is the best RTA placement in the room for the auto EQ feature? 10-15 feet in mid center on a mic stand about 5 feet off the ground?
Dennis
ahh.. thanks! So where is the best measurement microphone placement in the room for the auto EQ feature?
absolutely no way you can place a mic on a stand in a room with L/R speakers much less those AND subs...WAY too many arrival times to be of any use...
Try one stack only, (turn the other off or unplug it)on axis (strait out from the speakers centerline) 20-25' out with the mic lying on something like a towel (ever see the "Hitchhikers guide to the galaxy"?) to stop any reflections off the floor.
but if you haven't read the FAQ section posts on the auto eq process and it's quirks and pitfalls then I guess you probably should...in case you missed the "READ ME FIRST BEFORE POSTING" section on the front page here is the link...
viewforum.php?f=60
another potentially illuminating post is the "start here thread" where we stress the importance of gain structure.
viewtopic.php?f=61&t=959
were always here for questions...
