Using ZonePRO Designer V3.0 with netbook
I have loaded and been able to use the ZonePRO GUI on my Toshiba netbook (NB305). However the bottom of the program scene window is cut off. So is the configuration wizard window. I can move the window up with ALT + spacebar, but it drops back when I press enter to exit. I have tried different resolutions. I also moved the toolbar to be vertical on the side (this helped), but still don't get the full window. Any suggestions?
Make sure your DPI setting is set to 96. This setting should be located in Control Panel>Display>Settings>Advanced>General. Also, for now, you may be able to "Auto Hide" the Windows toolbar to be able to see all the buttons.
Hope this helps.
