Driverack PA + with delay speakers
Hi All,
I'm new here, i want to ask : can i configure my driverack PA+ for 2 way system for FOH and 2 stereo delay speakers?
Please Advice
Please Advice
What system (all speakers, amps, processing, gear)
what room (capacity, dimensions, room acoustics... etc)
what purpose ( live sound, DJ / KJ corporate...?)
Part of the answer is the DRPA doesn't have enough delay to be of much value... less than 10 feet...the rest is up to you...
I plan to use JBL EON 515 for FOH and EON518s for subwoofer, i also plan to put EON510 about 10-12 meters from FOH, so i will need to delay the speakers from FOH, is that correct?
Please Advice
Is there any way to get a center cluster in that church? that would give you the best results I figure, and a speaker like the D.A.S. RF 1264 (60x40 degree coverage would provide 120 degree coverage (2 speakers) and keep the sound off the walls better, have far better sound and projection (a 15 " woofer is NOT a very vocal friendly driver) Even if you can't center cluster (which offers the best intelligibility because there is no overlapping horn patterns to cause cancellations and modes) the 1264's are still a far better choice because they are set up to fly and will again offer the ability to keep the message on the people and off the walls. (and they are VERY reasonably priced)
Is this a "rock and roll" church? with worship band and all? I assume so since you are specing a sub?
The delay speakers could then be something like the Community CPL 24 series, small, light weight with mounting brackets (and come in black or white) and I have had really good luck with them in church spaces.... and they are CHEAP! ( if it is just a vocal re-enforcement system you could use the CPL's for the whole job. I know I did a 6 speaker install in the Catholic Church next door and they LOVE the system, and it's been in there for the last 6 years!
You could then get an amp that has delay DSP built in. Peavey just came out with a new series of amps that are super light weight, have built in DSP AND I believe 5 year warranty, and they are CHEAP! Like WELL under $500 for a 3000 watt amp with DSP built in! WIN WIN!
Sorry to be the bearer of bad tidings but you would have NOTHING but problems with that JBL system! Here is a link to the cheaper route that will make you a hero at the church...
http://www.northernsound.net/Sales/spea ... frame.html scroll down to the RF1264
http://www.northernsound.net/Sales/spea ... frame.html scroll down to the CPL 23/27
http://www.northernsound.net/Sales/catagories.html scroll down to the IPR series amps
Crown also makes the XTi series amps with DSP, but are more expensive.
I hope your not dealing with brand snobs in your church because this setup would give you FAR better sound and I believe come in cheaper! win win!
Be well, good luck!
Gagdet
