Home dbx Forum dbx Forum Archive READ ME FIRST BEFORE POSTING FAQs
limiters, An example of the math for setting them...
edited February 2010 in FAQs
This was posted by Ryan Jenkins on the PSW:
You can calculate the maximum power available to the drivers and set your limiters accordingly.
First you need to convert the power rating of your driver to Volts rather than watts.
Lets assume you have a driver rated for 600 watts at 8 ohms nominal. The formula would be....
Sqrt(watts*ohms) so sqrt(600*8) = 69.28 volts
Next you need to convert the volts to dBu using the formula 20 Log(volts/.775)
so 20 Log(69.28/.775) = 39.03 dBu
Now lets assume you have an amplifier capable of 800 watts at 8 ohms. We now need to figure out mow much gain the amplifier has using the first formula.
sqrt(800*8) = 80 volts. then we convert that to dBu also.
20 Log (80/.775) = 40.28 dBu
Now to find the limiter setting you subtract the amplifier gain from the dBu required from the driver.
39.03-40.28 = -1.25 dBu
So you would set your limiter for 1.25dBu below full output of your amplifier.
So if your amplifier has full output at +4dBu then you would set your limiter for +2.75dBu.
Hope that helps.
Now If your amplifier has a constant gain such as 26 dB or 32 dB gain then you would subtract the gain of the amp from the driver dBu
So for 26 dB gain the math would be
39.03-26 = 13.03 dBu for the limiter
Or for 32 dBu then it would be
39.03-32 = 7.03 dBu for the limiter.
All of these answers would give you ~600 watts to the driver depending on your particular amps settings.
There you go, now your are a little safer.
[Updated on: Mon, 11 June 2007 13:04]
Ryan Jenkins
"Two days until the end of when I don't know what to think. Three days until I start the cycle all over again!"
