No output gain from 576 preamp channel
Hello, I recently acquired a DBX 576 dual channel microphone preamp/compressor. The unit has worked fine for about a month, but tonight I powered it up and was unable to get any output gain from the preamp side of the unit. I tested every cable used, and they all worked. I also switched the meter to the Drive Level (input metering) setting, and I got a healthy signal. I tested the compressor channel separately, and everything worked beautifully. What could possibly be the problem? After looking inside the unit, the gain level pot seemed fine, and both tubes were working. Any help with this problem would be greatly appreciated.
