SONIC MAXIMIZER WITH DBXPA
I just bought a used Sonic Maximizer at a deep discount. Can I use it with DBXPA ? Can it improve my sound more ? I also bought a nice behringer feedback destroyer too, I know DBXPA has feedback suppressor but we still hear feedback when we try to crank up the volume. Can someone so me how to fix this problem or should I install the independent feedback destroyer? Thanks.
Have you set up your system to be flat and with proper gain structure in the READ ME FIRST section?
Sounds like you need to do some tweeking of the base system. However, once you get that done (if you still need to...) the sonic maximizer could be used as a channel insert to aid a poor sounding source (accoustic guitar, keyboard, thin vocal, etc), but other than that, no. The other feedback destroyer, should not be needed, but could be inserted on vocals that are giving you feedback problems, but again you should not need it once you get your system tuned. You could use it on your monitors.
260 = GOOD!
loose the sonic discombobulator...
