DriveRack PA Custom Setup Help
Hey Everyone,
I'm trying to help at our church with the sound system. We've got the DriveRack PA and it never been properly set up.
We've got a QSC RMX 1850HD amp
Ch.#1 - Subs
Ch.#2 - Tops
Our Speakers are;
Tops (Mono) - JBL's MS28
Subs (Mono) -JBL's JRX118S
Mono In
The Subs are Aprox. 4' further away than the Tops from most seats. How should I set the DriveRack for Input and Output, Crossover, Delays, and any thing else. We have a Mackie24-8 Mixing board and speakers in the wings of the church and monitors that are not connected to the DriveRack. The room acoustics are terrible with feed back and the sound system has high - med hi range mostly. We need a better/richer sound especially for mid range voice.
Thanks in advance,
Why767
Ch.#1 - Subs
Ch.#2 - Tops
Our Speakers are;
Mono In
Thanks in advance,
Why767
The tops fall off drastically below 80 hz. since they are 8" tops I'd cross closer to 120 hz, LR24.
I'd set the HPF for the sub @ W18 @ 45 hz...
HML 35.5
BW 12
-11.0 dB
HML 100 Hz
BW 18
Dra- I think it would be a good idea to put the wings on the DriveRack
Wings Amp
Yamaha P3500S
Speakers (Mono) 2-Martin EM26 , One on each side.
Monitors Amp
QSC MX70
Speakers (Mono) 4- Fender 1270, Two left and two right.
The Martins are rated 125w cont and 70-18K +/-3db.
Yes that would help your monitors greatly but you'd only have 1 mix and the measurement mic is required to get the full benefit of the setup...
If it is wired mono in "left" and mono out "left" with tops and subs only how should I configure the crossover? I currently have Input Mono and GEQ as Dual Mono.
Would it be better to rewire it as stereo? I could the input fairly easy but the out to the tops would be difficult.
Like this thread:
viewtopic.php?f=61&t=959
Or the stuff in the FAQ's?
viewforum.php?f=60
You will find a lot of the info to set up and tune your system...
You need to select Stereo and Dual mono... not necessarily in that order (can't remember) but one way you won't get the "not finished" and move onto the next section to eq...be it mains or monitors...
Two things can bring the "not finished" message when doing auto eq...
1. More than 4 bands fully cut or boosted..in the GEQ after an auto eq run,
2. Waiting for you to auto eq the other channel...
So, when you set up stereo with dual mono then you have as separate a signal path as your going to get in the DRPA. It's important to have the signal path all strait and again it's been a while but I believe I set the left channel as mains and right as monitors, that way your ready when you need to transition the mic for the monitor run...
Mic position is important... and if you have read the FAQ... Auto eq post you know that.. if not... read.
then ask questions.
I'm assuming that my LPF is @ 35.5 if it's set to HML 35.5? What is HML?
And the slope is BW12 and for the subs it should be BW18?
If I set the tops at 120 hz and the subs at 45 hz doesn't that leave out the sound from 45-120?
What is LR24 I can't find anything on that in the DRPA?
I know this must all be simple stuff for you but it's all new to me and I appreciate all you’re patients and help.
why767
1. In the case of the BW18 protect the sub speaker from damage from too low a frequency
2. In the case of the LR 24 the interaction in the crossover region is minimized
I would suggest this:
HPF (sub) (hipass filter.. the LOWEST frequency you want the speaker to produce) BW18@ 45
again we have chosen 45hz due to the power available
LPF (sub) (lopass filter... the highest point we want the speaker to go) LR24 @120hz
we chose that frequency because of the size of the low frequency speaker in the tops
HPF (MS28) LR24 @120hz
the 120 hz will also help with intelligibility of the MS28's and not get the subs too high in frequency so that they sound honky.
When you select the [xover] by pressing the button with that name on it you will be able to select the type and slope by using the [<prev] [next>] page buttons and the encoder (large wheel)
The HML refers to the Hi, Mid, and LO outputs and the one you are working with is highlighted when selected...
you need to sit down with the unit and find out what EVERY KNOB and dial does. Simply select an unused preset by pressing the [program] button and rotating the data wheel...press the big knob in to load the program. Then play with all the features till you can navigate about the DRPA with confidence. Use the block diagram so you can see what the flow of the device is...If you don't have the manula you can download it here:
http://www.dbxpro.com/Literature.php
You can also download the GUI for the 260 and get an even better idea of how the tools in the driverack work... that is is in the downloads/software firmware
Once you select the xover types and slopes and set up the speakers you will want to save this preset to a location you can find it and name it... that is all in the FAQ section as well...
