Driverack PX with Bose L1 Model 2 and Mackie HD1531
1st post. 3 yrs.DJ with lot's of toys. Bose L1Model2 with 2 B1 bass, T1 Tonematch mixer and a proud owner of a pair of the new Mackie HD1531 3 way speakers. I just bought a Driverack PX hoping for easy set up on EQ's, Compression and getting rid of the Feedback. I always encounter feedbacks on my DJ/VJ gigs when I have a special number with a Keyboard and 1 vocalist on a shure wireless. I don't have a powered sub yet(too many choices) till Namm is over but the low end on my 3 way mains and 2 Bose B1 Subs pretty much cover the low end needed for now. Anyway, I have an Allen and Heath 16 channel Mixwizard3, RANE TTM57sl dj/vj mixer and BBE 882i Maximizer. I just need a quick pointers on my hook up and hopefully utilizing every gears I have.I don't see my speakers on the list in the manual and will I have a problem placing my Bose L1 model 2 in between my Mains? Where do I series the Maximizer in my set up? I almost forgot, I also have a DBX 266xl as a limiter. Any info will be greatly appreciated.
ed
ed
So your a DJ playing heavily compressed music and you want to add MORE compression? Not a good idea...compression can ADD to feedback problems...
Your having problems with feedback with which system? Both together?
Are you using the l1 as monitors ro something? because I have a band that has the sticks and when I do their larger gigs the guitar player has used his stick... and while it worked ok...the multiple paths and arrival times of this setup made quieter operation very difficult...
I would highly recommend loosing the BBE sonic scrambler...the Driverack makes it obsolete.
you don't need presets, you need system setup and gain structure found here:
viewtopic.php?f=61&t=959
you'll also find lots of info on auto EQ and using the driverack in the FAQ section...
viewforum.php?f=60
Lots more info needed if you want help...you need to be specific here...
