Which Driverack for DJ JBL Setup?
I have 2 JBL PRX515 and 1 PRX718. Those are curently conneted to a Pioneer DJM800. I play your standard club/dance music for the most part. Locations are small clubs and outdoor party's ranging from 75-200 people
From reading through the forum, it seems like the DRPX would be ideal since I definitively want to change the crossover point from the standard 120Hz off the PRX718 to somewhere between 80-100Hz. Also, I want to try and "flatten" out my system as much as possible using "outdoor auto EQ" method. Then after, tailor eq at venue by ear as needed. If I am there before people arrive, maybe even put the mic in a couple of places and try to average out readings.
I don't foresee needing more inputs since I don't plan on doing a more complex setup than 2X3 or 2X4. Also, in this type of configuration, my guess there is not much need for tweaking delay. I might add another sub down the road. Also, might start doing events using mic, but DRPX has the AFS feature so it seems to cover that.
Am I correct in the above assumptions or missing anything? Would there be any reason to go DRPA+ or even DR260 (besides GUI) for my type of setup?
Thanks in advance.
Thanks in advance.
