PA+ Rackmounting in PU Case
edited December 2009 in PA General Discussion
I just got a new PA+ and want to install it in a Gator PU rack. I need to reconfigure the input panel from 90d to flat in the bacl to be able to close the case and keep it hooked up. I took it apart last night and the connections are not long enough to move the back panel to the flat position without destrying something. Look at the attached pic. I see no why to make this configuration work. Ideas????
  • IF it were not in warranty you could just splice longer wires. But, if you do that warranty would be voided.
    Would the panel roll over and mount to the front panel (upside down)?
    How about 90 deg connectors?
    How about regular connectors, leaving the shells off?
  • The warranty is already void...besides...open like that you expose the sensitive electronics inside to spurious RF and all manner of electronic waves... NOT a good idea...
