Home dbx Forum dbx Forum Archive DriveRack 200 Series 200 Series Configuration Wizard
driverack settings EV TourX series
I am thinking about buying a driverack pa+ or 260, but i like to know do they have the new tourx series speakers from EV in the wizard?Could I still use the driverack if they are not in there and what settings should i use?
  • Are you intending to use the passive crossovers in the tops you are going to use? If so you don't need ANY tunings because they don't exist...HOWEVER... if you are wanting to Bi-amp the tops and add subs you will need to contact EV for tunings.
    The best solution is going to be the 260...I have listed the differences here:
    viewtopic.php?f=60&t=2114
    We are here for questions...
