SETTING SUGGESTIONS?
Hey guys looking for any good setting suggestions for my Driverack PA :?:
With the following equipment I'll go for a 2-way system for now.
2-JBL SRX725
4-Cerwin Vega EL-36b
1-QSC RMX5050 amp
1-JBL MRX1200 amp
Other extra info I have a DBX 31ieq for the main mix and I'm runing 2-DBX 166xl after the pa x-over as a 2-way system as a speaker protection. I don't have the RTA mic for the drive rack at this point...
I might use the QSC amp to drive my 4 Cerwin subs & the JBL amp to drive my SRX mids or vise versa but not sure at this point.
I will be running this system for bands.
Thanks in advance
2-JBL SRX725
1-QSC RMX5050 amp
1-JBL MRX1200 amp
Thanks in advance
8)
SRX725 - 1200w / 2400w / 4800w 99db sens 136db peak each
EL36 - 250w / 500w / 1000w (3" vc) 106db sens 134db peak each
rmx5050 - st 1100 (8)/ 1800 (4) / 2500 (2)
- br 5000w (4)
Based on sensitivity (spec) you'll need a 4:1 power ratio, tops to subs.
What the heck is a JBL MRX1200???????
Dennis
Dennis
Most folks at Harmony Central like no more than the continuous rating of a speaker fed to it. Most folks at PSW like no less than program and lean to peak.
I like some, lean to...it depends. 8)
I have melted vc's with program power (w/ HPF @ 40hz).
Q: Can you power a 20w 1" horn driver on an RMX5050 with a full range signal w/ attenuators at -0-?
A: Yes.
Q: Can you power a 20w 1" horn driver on an RMX5050 with a full range signal w/ attenuators at -0- and 4v of input?
A: No.
PS- not directed at anyone, by the way. Just felt like ramling.
Dennis
I have never had a problem with too much power...I have had trouble with too little...
G[/quote]
The response you would get on HC (not a good arguement) and in a snide & huffy tone, "Then every time you turned DOWN the volume you'd blow a speaker."
100w / 200w / 400w speaker with pink noise applied through amp at max output (non-clipped / clipped (2x output))
25w amp )
50w amp )
100w amp)
200w amp)
500w amp) :x / :evil:
Or something to that effect.
For regular Rock & Roll, country, etc and unclipped amps you possibly would get all smiles.
Again, it all depends. If it's loud enough and sounds good and the meters are not pegged and the amps are not clipping at all, there is no such thing as underpowered. Underpowering is when you need 6db more output from the speaker (which has 9db more to give), but the amp can't give any more without clipping. It's symmantics (sp).
It's not the power of the amp. It's the power coming out of the amp.
Potential energy doesn't kill speakers. Kinetic energy kills speakers.
PS - What was this thread about?
That doesn't even deserve a response...I would definately like to see them postulate that crap on the PSW...that whole HS/GC/SA sales crap doesn't fly here...
I guess that since Crown, QSC, Lab Gruppen, and Camco to name a few, and EAW, JBL, NEXO, Meyer, Adamson, and d&b audiotechnik all specify 2 to 4 times the PROGRAM power rating (NOT the RMS) for speakers... I assume that the conversation would be very short and VERY one sided...
The JBL MPX1200 is underpowered for your application but still do-able. Another RMX 5050 would do better. Or get another MPX1200 and use one bridged on each pair of EL36 and use the existing 5050 on the JBL's.
Dennis
So I found 800 watts @ 8 ohms? is that correct? well... if it's true, and Dra's petrifying HC predictions tell us that 800 watts (on a speaker that is rated 1200 W / 2400 W / 4800 W right on the JBL site :shock: ) that 800 watts is SAFE
Therefore...as Dennis so aptly put it... we dis-agree a lot... the 80 hz he suggested would perhaps serve well on a system that is properly powered... (I would however like to know what his theory is on placing the xover right on top of the kick primary 1st harmonic frequency :?) as in his recommendation of another 5050...for the tops...but it will also work for a system where the subs aren't "crankin" all the time, and since the subs can produce 300 hz (at who knows WHAT efficiency, as there isn't a frequency plot for the sub to be found...)Heaven knows horn loaded subs get honky about 120hz...so there are only a few real possibilities and they are ALL really easy to compare with the driverack...
Try 80 hz, try 100 hz try 118hz... and anything in between... if you want to try overlapping the frequencies use BW24 filters... LR 24 works well for adjacent frequencies with no overlap. Steep filters like BW18 are best for HPF's on subs, and LR6 is a good filter if your going to use a LPF on the horns as it has less frequency skewing ...
have fun good luck!
so... keep us informed!
Gadget, on a number of occasions, you have brought up 80Hz being " on top of the kick primary 1st harmonic frequency" but I haven't got my head around the downside of the xo point being there.
Dennis
I'm tired and most likely not thinking all that acutely...but as I recall, the kick drum 1st harmonic normally falls between 60 and 80- hz, right? When you read many of the articles about recording and or producing a kick drum they use typically, 80hz... Peavey... in the "boundary cancellation" article posted here uses 80 hz...I know you too will acquiesces to working that area...
Well, if we were talking about 60 hz that would be one thing, but were not....really...that's typically too low a frequency. However, when you specify a more accurate kick frequency of 75-80hz and put a crossover on it you are landing on THE one ..ONE note wonder of the system...the one and ONLY one note wonder worth fighting for....So, with THAT important an element of the sound doesn't it make sense NOT to place the crossover point on top of such an important hallmark?
I mean...you know what a crossover point can do to the sound....why place it on one of the most important elements of the mix? For me a few hz north or south of 80 helps steer clear of the kick impact...that's all I'm talking about
you outta be around when we start on blose..
carin and sharin...
You have a couple of issues to deal with.
You have 4) mid 15"s and 4) sub 18"s - a negative. (balance)
The subs are 7db more efficient - a positive. (Although it could be above the desired x-over point)
The subs gain 3db by coupling sub pairs and maybe 6db (total) if all 4 are clustered together.
I think you are going to have to try different configurations with x-overs and amp use and pick the best.
Here is some math.
Per speaker / no coupling factors included. SRX are capable of 136db. No spec for CV, but probably 137db.
RMX stereo on SRX - 1800w / 131db
RMX bridged on SRX - 2500w / 133db
MPX stereo on CV - 600w / 133db
MPX stereo on SRX - 1200w / 130db
MPX bridged od SRX - 1600w / 131db
RMX stereo on CV - 900w / 137db (rounded up)
