PA+ setup
I have read several of the posts and have gained some valuable knowledge, I am trying to soak it in due to the fact I am a newbie and need all the help I can get. I am wanting to setup with 2 SRM 450's and 1 1501 active sub for FOH, and 2 Behringer B212A active speakers for monitors. Am I right to run a 2x3 stereo input, dual mono GEQ with the 450's on the RH, the B212A's on the LH, and the sub on the Left(Mono) Low? I have went through the setup wizard, all is good except I cannot set for the B212A's once I have entered for the 450's. Is there a way I can set these separately? I read somewhere about using the "Full Range" preset, but I am not sure on the hookup that way. Also, with the former setup I encounter a problem at the Auto Leveling stage, as it goes straight from Left to Right balancing. So should I auto level Left (monitors) first, and then hit previous page and then auto level Right (mains)? I would be most appreciative of any and all help I could get in this area. Thank you so much.
In a nutshell...
FOH to right input.
Monitors to left input.
EQ(R) for FOH.
EQ(L) for Mon.
High output R to FOH tops.
Mid output R to subs.
Low output L to monitors.
(You can change the above(output config) to whatever is most "logical" for you, remembering that the high outout has 1 extra PEQ filter to play with.)
Go into the x-over section and set (in my example) the low filter to be full range (a lot of people like to cut off the low end for clarity, I like 70hz or higher even, and cut the high end about 15-17K). Then set the filters for FOH in the high and mid outputs.
Auto EQ L & R (mic position to suit) and your done.
Ideally you should set up outdoors and then transfer the info from the GEQ to the PEQ to flatten out any naturally bad areas as is describe in several posts.
Hope this helped.
Set a HPF on the subs at 45hz BW18.
Use LR24 filter types for the x-over point.
Depending on which output is going to the HOH highs (the high outputs don't have an LPF (high cut)) you can cut off the ultra high end at 17K (most speaker won't reproduce that anyway) or leave it as "out" (no filter).
On the + I believe it's opposite... select stereo, then dual mono GEQ ... the idea here is to get a path through the DRPA that allows separate signal paths...Then, the idea is to have 3 separate outputs ... 2 for FOH, and 1 for monitors. This requires a different output for each. I use 'L' Hi outs for mains, 'R' mid outs for monitors, and 'L' lo outs for subs...Now perhaps the monitors aren't the best and they could benefit from an additional PEQ then the monitors would go on the hi outs, and the mains on the mid outs. Actually as Dra pointed out any output could be used as a fullrange out. Technically were putting the mains on a crossover and the monitors on a band pass filter.
As far as the auto level set in this config I don't think it will work... you'll have to set that yourself. When set up properly, you will enter the auto eq sequence (in this case as set up above) and when it finishes it's first pass (mains) it will immediately start the other(monitors) So, have everything ready it goes real fast.
Remember indoors the subs will not be eq'ed properly...as standing waves will collect and skew the results...see this post in the FAQ section:
viewtopic.php?f=60&t=949
you will find out that auto eq is marginally useful indoors ....take this from that article if nothing else...
As for the equipment you have there isn't much benefit to entering the actual models in the wizard but if they are in there.. you can use them. It will only give you starting points... probably 100 hz LPF/HPF for the sub/hi mains and thats fine, you'll have to set the monitor bandpass filter yourself..set the HPF @ 60hz BW18, and the LPF to 12.5khz LR6.
Remember to have everything set up and ready to go as it all happens pretty fast with the DRPA+.
Just purchased a DRPA+. Brand new to this stuff so I was hoping I could get some help.
I have been reading the forums and have been trying to figure out the best way to setup my system.
I have a 1000 guest gig this weekend and wanted to make sure the sound was perfect.
I have read not to use the AutoEQ wizard since it doesn't work so well.
Can't wait to try out the AFS.
If I try to do the auto system setup for some reason it skips over the mid section.
It only asks for the highs and lows.
So for now I am using the preset for full range 2x6.
What is the difference between Stereo 3 way 2x6 and Full Range 2x6.
Here is what I have:
(2) RCF ART 322A for the highs
(2) JBL SoundFactor / (1) Crown XS900 for the mids
(2) RCF ART 705AS as the subs
I was wondering if you could assist me with the xover setup and anything else that I should be doing.
I have to work on the gain structure since it's not so easy with powered speakers.
Any help is appreciated.
Thanks!
I may move this to a different thread... you should have started a new thread...
It's a big hall, around 200ft x 200ft, and that is all the speakers I have access to.
I'm assuming the 322A's would handle the highs, the SF25s would handle the mids and the 705AS's would handle the lows? Does that make sense?
Sorry...
I guess I'm trying to do something similar to the following except I have jbl sf25s in the mix:
viewtopic.php?t=1190&highlight=
Something in the line of 45-90, 90-200, 200 - 20K?
Not sure what this means:
Still learning the buttons for the PA+
Whatever you guys do be the best configuration for the PA system I have.
I'm not too sure with the xover settings. The speakers will all be setup side by side next to the stage. My friend told me to get a feedback suppressor... and the store told me to purchase the PA+.
Again.. I'm brand new at this. Any help is appreciated.
After reading the manual.. I still can't figure out how to change the GEQ.. after the AUTOEQ is done.
DRA & Gadget... thanks for your responses.
I wouldn't do that...
I suggest the other solution Dra spoke of that has the speakers splayed on either side of the stage... HOWEVER those are BOTH 90 degree horizontal coverage... That means 180 degree coverage on either side of the stage...
You won't be able to cover 1000 people with that rig... no way...that rig is a small venue setup at best... sorry...If the room is long perhaps the 322's as delay towers (without the delay available :roll: )
What are the dimensions of the room?
I'm trying to use the wizard since it contains 4 of the 6 speakers I will be using but the PA+'s setup wizard skips over the mids section. It only asks me for the highs and lows.
Should I choose a 2x6 full range template instead and tweek that?
45-90hz for the lows, 90-200hz for the mids, 200 - 20Khz for the highs
From reading the other threads i'm assuming the lows would use the BW18 setting and the other two would use the LR24 setting?
Sorry for all the questions.
Can you fly the 322A's and let the JBL's blast into the crowd out front... the dancers? That is the only way I can see this working with what you have...if you can get the 322's high overhead to try and cover the back of the crowd better...
I can place the JBL's on top of the subs on the sides of the stage which will face straight to the dancefloor, and then I can have the 322s on stands 25 feet away faced to hit the back of the room?
This is what I mean:
RCF322 <25ft> JBL25RCF705AS <STAGE> JBL25RCF705AS <25ft> RCF322
Would that help with the "chaos"?
The thing is that the sound from the JBLs will take 22.2 ms to get the 25 feet then the 322's kick in and it sounds like an echo...7ms is noticeable...
I can also move the 322s closer up towards the dance floor and away from the stage as well while keeping the subs and jbls next to the stage.
Otherwise I'd try and get the 322's WAY up un the air to fire over the crowd to the back of the room... you don't have enough to cover that crowd any way you look at it...
Well, the only thing you can do is try and see...I can't believe that the JBL's will project very far in a crowd, maybe 50 feet would work, but the farther you get away the more the difference is gong to be noticeable...How high are the horns on the JBL's when on the subs?
And, since you have an already bad situation I suggest if you can corner load or at least wall load the subs and put them together you will get 3db of free low end sound by putting the subs together, and up to 3db more for a wall/floor combo and 3db more if corner loaded...
but the dance floor will have basic coverage right? People in the back will be able to talk...
This is exactly what I'm going for....How would I organize the speakers in this setup?
Can you give me the xover frequencies for the speakers?
Thanks so much!!
HPF sub BW18 LPF 100hz LR24
Wow, thanks for taking the time out to draw a diagram for me.
I will go with the "better" setup since it will work best with the room that I am in.
I have been placing my jbls on top of the subs for a while now, I guess I was wrong for doing so.
Thank you for the xover frequencies as well.
Much Appreciated!!
Go here:
http://webphysics.davidson.edu/Applets/ ... fault.html
and move the red dots around... put them side by side in the corner and see how strong and smooth the wave pattern is, now take them and put them like they were under the JBl's on either side of you amd see what a mess it makes... those fingers like extensions are comb filtering... the black area's have no, or very low bass... and the fingers are bass heavy...
Move the dots around and see what happens... put them close but not touching... on top of each other... you'll be amazed what happens!
remember this... at the frequencies we work with... the subs need to be LESS than 2.5 feet (together is best) apart, or MORE than 52 feet apart!
Sorry to bother you again..
but the 2x6 all custom setup... I'm using template 24 (I think thats the number) on the DRPA+ which is full range 2x6 and then i'm going into the xover section and setting up the frequencies. is this ok?
Like I mentioned before when I run the setup wizard it never lets me choose the mids.
Heres what happens:
Hold down setup wizard:
It asks for mains: I put in custom
then it asks for subs: i put in custom
And thats it.. it never asks for mids.
Am i missing something in the setup?
