260 vs DRPA what's the difference? and now the DRPA+
Here's what I wrote recently... on another forum...
Driverack 260 vs Px DRPA
GUI operation for fast visual manipulation of parameters , with multiple windows so you can monitor, and manipulate much easier and faster
Input mixers
Choice of 28 band GEQ or 9 band PEQ input Eq (no choice DRPA)
2 pre xover Inserts with the choice of
a. AFS
b. AGC
c. compressor
d. gate
e. notch filter
f. strait wire
g. Sub synth
(Fixed @ AFS and Sub synth DRPA)
Pre crossover delay, and the ability to freely redistribute the available delay between the various locations pre/post xover and 2.7 seconds of delay versus 10ms fixed per output and no pre-xover delay
Routing of any input to any or all outputs
Multiple filter and crossovers from 1x1 wire to 2x6 crossover
Bessel xover types
4 peq’s per output (3 hi outs and 2 mid and low outs DRPA)
Brick wall limiting
Multiple level password security (single level password anyone can look up and defeat DRPA)
You can run the GUI over 300 feet of snake
Ability to link and unlink modules
Copy and paste function
You can label outputs whatever you want
Realtime RTA on GUI and display screen
Update via serial bus
mutes on every output (DRPA+ has as well)
to name a few…
The DRPA+
Adds realtime RTA and mutes to the DRPA platform and a far superior Auto EQ algorithm...There are more speakers/amps in the menu (not that a non bi-amp speaker even needs a preset... :roll: ) and auto level for balancing the system prior to auto eq...a new interface so you'll need to learn a few new bits from the old DRPA, but it's basically the same platform...
3 peq's for the Hi outs
2 peq's for the mid and low outs
10 ms per output alignment delay
no brick wall limiting
NO GUI
Input mixers
a. AFS
b. AGC
c. compressor
d. gate
e. notch filter
f. strait wire
g. Sub synth
Bessel xover types
Brick wall limiting
to name a few…
The DRPA+
NO GUI
