Connection to a single amp
Hi.
For the past year or so, i've being using the Driverack PA, with 2 power amps. Recently i have purchased a new PA system. Dynacord Powermax 5. This system has a single power amp with its own built in crossover. My problem is, I would like to use the Driverack PA, for it other features, AutoEq, etc. I dont know what outputs to use on the Driverack. Also, do I have to something within the presets?
Any connection info this setup would be a great help! Thanks.
I'll be interested to see what more seasoned users suggest.
Thanks for the reply NatJAg.
I need to select outputs from the DR. Im not sure which set, low, mid or high. I was hoping i could send the audio from the DR that would bypass the crossover feature, and just use the other features.
I've posted a link below to the system im using. The second half of the manual is in english.
Thanks again.
http://www.dynacord.com/downloads/ManualPM2600.pdf
Thanks gadget,
Excuse my ignorance! but I'm not sure what you mean, when you say a blank slate filter?
Dennis
Thanks guys for the info and the speed of the replies. Greatly appreciated!!
The crew at the DBX forum...
sorry...
Kinda like when DRA catches me ...ain't often but he sure does like rub it in...
Dennis
I'll add one thing. I would consider setting a HPF. I'm sure the DCP has one, but where and how steep?
