Driverack PA +...Use two for 4 monitor mixes?
If I had 4 monitors couldn't I use two of the Driveracks and run 4 different monitor mixes with that set up? I already have one for the FOH mix but the monitors need some work. Seems like that would work right? The right and left on both would be coming from aux 1(r), aux 2(l), aux3(r), and aux 4(l) off my mixer.
NLP
NLP
GEQ/RTA/Auto EQ
Feedback eliminator
and
Post xover PEQ
The 260 gives you total control of every input and output...except for signal path routing... that is fixed.
2... 24 band output PEQ's
2... dual 31 band input EQ's, a
Enough delay to stretch out about a mile...
ALL the tools...
That's what I'd do...
As I said... the DRPA is limited, and you will have 2/ 28 band GEQ's, and 3 Peq's on the hi outs and 2 on the mid and low outs...
You will have Dual Auto EQ
you will have AFS
No dual compression, no dual limiting, just one value for both mixes.
But yes it will make a difference!
Oh and tell Um Gary ... from the DBX site sent you
NLP
viewtopic.php?f=60&t=1049
is the thread about that process...I am using a generic el cheapo converter and it works fine...
There is a tutorial here:
http://www.dbxpro.com/Download/Training ... orials.htm
that actually uses the GUI for the training...
It's really not that hard to use, but there are some hidden features...the key is just moving around and using the display. I like to set up my screen so I can watch a number of things at once...like this:
But take the training, and then see if you have more questions...
What's the best eq type for monitors? Flat, My band, Performance Venue, or DJ? I currently have them set up on Performance Venue and they sound really good, but just trying to get other opinions here. Would eq'ing them as "flat" make the feedback go down any? Obviously it would in some cases but does that matter much?
Remember it's a simple thing to have presets for each of the different curves, and see which you like best... for which applications.
Which output did you use for your sends from the DRPA+. Was it the Mids
Cheers Adza.
