drive rack px and mackie srm 450
:?: Hi all...I'm contemplating purchasing a dbx driverack px to use with my mackie srm 450 speakers....I'm a newbie to the pa world, and dbx. Do you think that this unit would be the way to go? I play country-rock music, five piece band, in bars. Thanks for any help! Rick
The DRPA at least offers the Auto Eq, GEQ and feedback eliminator that you can use to eq, setup, and eliminate feedback from the 2 mixes...
A measurement mic is necessary for this purpose though, so you'll need not only the DRPA but a measurement mic as well.
The Rational Acoustics site has a great inexpensive mic for about $80...
There is one possibility that the PX could work, and that is if the mains and monitors are the exact same speakers...and the same mix...
Same HPF, same EQ cuts and boosts, same limiter, etc. So if the monitors feed back at 2K, when you pull it in the monitors, it will pull in the house also. If the house mix get a hard kick hit and the limiter grabs it, the monitor mix will be limited also (even with no kick in the mix).
Now you just have to find a happy middle ground, or make sacrifices on one side or the other (or both).
Good luck.
