Sound System cutting out
I have just recently started using the driverack pa and since i have started using it i have had issues with the pa cutting out mid performance. I know that the db meter on the driverack isnt peaking but at unity my amps are peaking and the failsafes are cutting the amps off for about 20 secs. i just remembered today of the db attenuator on the xlr inputs and that may be the problem but could it also be the way i am pinking the rooom. When i am pinking the room to performance level the gain is usually well above 0db. i did not think about it untill today that the db level of the pink noise could coincide with the main levels. so maybe i am overdriving the amps from the driverack but my input from the console is not peaking. could that be my problem as well. at that point is the output gain of the drive rack greater than what the input reads. the quick fix for the past three shows has been the sound man pulling the master down around 15-20 db to keep the amps from peaking but at that point i have lost gain structure. i have never been a fan of main mix compression but maybe thats the answer as well. i am going to check out the db attenuator tomm but if anyone has any advice please send it my way.
I.E. if we have the same exact amps for ALL speaker components, and we have a 3 way system that has a horn that is 107 db efficient (@ 1 meter and with 1 watt input power) and a mid range that is 98db efficient (same as above) and a sub that is 94 db efficient... we would somehow have to account for the difference in efficiency ... correct? we have two things at our disposal ... the amp sensitivity control, and the crossover gain control... I know this isn't intuitive...but we can use one or BOTH to accomplish this task, here we concentrate on simplicity as to not be too confusing, and as such we would suggest that the horn, being 107 db efficient will be 13 db MORE efficient than the sub, and 9db more efficient than the mid range... we either need to turn DOWN the horn amp then 13 db with respect to the sub, or use the xover gain control ... or both... real world situations have us using a LESS powerful amp for the horns simply as a matter of cost...SO, if the HORN amp is less powerful than sub amp...then we need to take that into consideration as well...
Now, that said... you haven't provided enough information for us to be able to discern what is really happening here... did you read the \"Read me first before posting\" section? Because if you had... you would know we require ALL SYSTEM COMPONENT information to even give you a response... which you have not provided... NOT trying to be a hardass here... BUT look at it from our perspective... you are obviously not a total beginner... but you haven;'t given us much to go on now have you?
Respectfully...
http://www.dbxpro.com/forum/index.php?s ... ca1e10270e
See the heading READ ME FIRST BEFORE POSTING?
Open the START HERE thread.
1. The amps are limited down from their rated power when you engage the limiter on the amps.. that is to say with an amp of 2400 watts you actually limit the output to about 1800 watts...
2. In the normal mode...the amps duty cycle is expected to run well under 30%... the is to say if the amp can put out 100 volts continuous it would only normally average 30 watts... when you engage the limiters, the duty cycle will start to spiral up... once the duty cycle reaches 50% the amp starts to heat up, and I believe you are experiencing thermalling...
3. What Dra was pointing out was that you haven't set up your gain structure... If you had, you would know when your amps are near clipping...because the mixer would already BE clipping...there is a method to this madness...
4. You are overlapping the crossover and that is also contributing to your woes... did you realize that with that large an overlap that you are suffering cancellations that you are having to push harder to recover from? when two speakers in near proximity reproduce the same frequencies and the electrical signals arrive out of phase ...cancellations occur... Why do you suppose speaker manufacturers that have 2, 15 woofers together in the same cabinet... cross one of the 15's @ about 300hz? It's a quasi~3 way design that limits the interaction in the lo mids...They also use a BW 24 filter design to limit the interactions in those regions...
I would
a. dump the limiters
b. set the crossovers @ 45hz BW18 HPF, 120 hz BW24 LPF subs
HPF BW24 @ 112 hz tops
c. do a proper system setup and gain structure as per the \"Start here thread\"
http://www.dbxpro.com/forum/viewtopic.php?t=959
You know, those TOC speakers can REALLY CRANK :shock: when Bi-amped, and powered properly.. I know we have 6 in our extended network... Those will keep up nicely with 6 LABsubs which outdoors can be FELT... nearly a mile away!
Dennis
Man, that's what those PEQ's are for....just remember, rather than surgical narrow bell curves try an broader Q like around 1.o to start with... If you find some harshness in the upper mids try a Peq there as well...but use a slight cut... move it around and see what happens, play with the gain as well to get it dialed in right!
