X-over settings EV G118-EV Z-4
Hi, I'm mobile dj- party music
I need help with the crossover settings for the following setup:
2 subs EV G118 400 rms
amp Peavey PV2600 550 rms
2 tops EV Z-4 400 rms
amp Crown XLS 802 500 rms
Mixer Dateq Apollo
thanks from netherlands
  • You're under powered on the top, but OK.
    You're really underpowered on the subs and neither amp is spec'd to run bridged @ 4ohms.
    You'll probably need to dial the tops amp back a bit to balance to the subs.
    All things considered I'd set the subs to :
    HPF 45hz (maybe 50hz) BW18
    LPF 90hz (maybe 100hz) LR24
    Tops:
    HPF 90hz (maybe 100hz) LR24
  • Well, Crown says nothing of 4 ohm bridging, but ZZsounds.com says 2100w.
    Maybe someone else can clear up the mud.
    IF that is an option then then setting from earlier would be changed a bit.
    PS - More mud. There are those that would say you are perfectly powered (even a tad high). There is a valid arguement for both schools as it comes to killing speakers.
