New owner of drive rack pa
Hey guys Im glad to say as of today ill be a new owner of a dbx driverack pa.
I want to pre-set my settings now so that i dont have to mess around with my audio too much when we gig
i will be using
4 cerwin vega folded horn subs
2 srx???? as tops
2 jbl jrx
all hooked up to behringer amps
i gett all the stuff about setting it up. my question is should i plug in everything and run the setup wizard and just run the eq part when im at the gig right? I dont want to hook up all my microphones and all that right now plus i have no space where to do that?
i will be using
2 srx???? as tops
2 jbl jrx
http://www.dbxpro.com/forum/viewtopic.php?t=959
Is a start here system setup and gain structure...
http://www.dbxpro.com/forum/viewforum.php?f=60
Here you will find... (in no particular order) a lot of info on the Driverack and other subjects...Here:
http://www.dbxpro.com/forum/viewtopic.php?t=960
is a step by step setup...and here:
http://www.dbxpro.com/forum/viewtopic.php?t=949
Is the Auto EQ tutorial...
Here:
http://www.dbxpro.com/forum/viewtopic.php?t=953
Is a method for flattening your speakers INDOORS without too much fuss..
In short what were discussing here is how to set up your system and tune it flat so you can go into any venue and have a good starting point...
More questions?
Good luck, good sound is no accident! happy reading!
