Driverack PA+ setup w/QSC CX254 and Crown XTi2000
Looking for setup with QSC part of system.
Crown XTi2000 - running (2) EV SX300E for highs/mids
QSC CX254 - running (2) EV Eliminator i Subs
System set to run in stereo.
This QSC is a 4-channel amp, setup bridged (1/3 left sub and 2/4 right sub) @ 500w per sub.
Need to find setup info for this QSC amp with the PA+ as there is nothing showing or any threads. Any help would be greatly appreciated!
Would RTA take care of this problem alone or still need setup info?
  • Well, your pretty under powered so first off we need to address that...425 watts @ 8 ohm... the speakers are rated @ 600 watts program, 1200 watts peak... so your borderline with little or no headroom...
    The subs are underpowered too, so here's what I'd suggest:
    1. HPF for the sub @45 hz BW18
    2. LPF for the subs @ 120hz BW24
    3. HPF for the tops @ 120hz BW24
    Next you want to set up the mic and go into the auto level where the output level of the 2 amps will be set...Note follow the prompts...mic 10-15 feet out
    Next do the Auto EQ... Try a couple locations and see which sounds best
    report back...
