Trouble with Subs
Hello guys, I hope you can assist me with an issue I am having with my current system. I have read the read me first and most of the posts regarding the DRPA and PX. I have an all powered system.
My subs do not give me that in your chest response that I am looking for and I hope after I describe current set up, you can at least point me in that direction.
SYSTEM:
4 EAW NT-S22 (2000watts)
Response: 35Hz to 130Hz
Output: 126 SPL
8 EAW NT-L720 (1500watts)
Response: 75Hz to 21 KHz
Output: 127 SPL
I use the DRPX as my main processor.
Thanks.
SYSTEM:
Output: 126 SPL
Output: 127 SPL
Thanks.
Since EAW went offshore I'm hearing disturbing things about the quality control...
I did notice an increase in output when put in clusters of two or more for the coupling effect.
The cones should be moving in the same direction since it basically 'Plug and Play', ( I know....newbie questions and answers, but please bare with me).
Thanks.
Now, I'm wondering if you shouldn't access the tops DSP (if you haven't done so already) and apply some delay to the tops to align then with the subs...
Also, what are you using to set the output level of the speakers? What are you using to balance the subs with the tops? Are you using the PX xover gain controls and if so what are you doing with them?
What crossover slope?
I would suggest trying this:
1. HPF for the subs 20hz BW6 (basically letting the subs do their own HPF
2. LPF for the subs 120hz BW24 gain +6
3. HPF for the tops 100 hz BW24 gain -0-
I set the subs level at 41% in the PX ( as the manual describes) and the PX crossover gain controls to balance them.
DR. J, I have used that trick for the last couple of years but the way the sub is designed, you can't see the transducers without taking it apart and it is a powered unit.
Another thing that I noticed is that with powered subs, it takes about an hour or so before it kicks in, has anybody ever noticed that? Cause I also own some EV-SBA750's?
Thanks guys for all your help.
I will try those settings and let you know how it goes.
You guys do such a fabulous job on this site, keep up the good work!
BLESS!
Dennis
Dennis
Thanks.
Silly me, :roll: I had the compressor on and was rubbing the signal of ALL the dynamics
I had the subs kicking yesterday and everyone was happy
Do you think that I should use the limiter in the module or let the speaker limiter do what it should?
If I do use the limiter on the DRPX, what would be a good starting point for mainly DJ music?
Thanks again for all your help.
Glad you found out what the real problem was... Got a minute to describe what you think about those speakers? Coverage, sound quality...quantity...ease of setup. What experience have you had with other speakers prior to these and what reason did you land on these? I assume they are somewhat spendy....
Previously I had the NT-29 monitors and loved them and that is why I went with the NTS-22's.
Now that I have them set up properly, coverage was excellent, was a little peaky but adjusted the PEQ and was much better. Set up was very simple, no problems there at all, I used three subs yesterday with three L720 line array cause this part of the world the cultural taste is a bit bass heavy with a deffinite rounded tone.
I have has the EV SX-A750 which is a single 18" with 750watts but the EAW blows it out of the universe.
Spendy.....will a little bit!
Now I know that you can use passive subs with the PX, I also have some EAW FRZ-250 which are dual 15" subs that I power with 2QSC RMS-1450 driven in bridged mode, can I use both passive and active subs on the PX and if yes, how would I accomplish that from the PX?
Now, that said...what would you want to put those underpowered FRz's with those tops for? the NT's go lower, have more power/output, and I'd bet probably offer less distortion @ rated output?
But anyway, With that low power problem, I'd set the HPF @ 40hz minimum, BW18, probably as high as 47~hz the LPF is less of a problem since the FRz's go all the way up to 2000hz.. so you could use the same HPF as the NT's...
Dennis
Trying to keep things as simple as possible.
I was also thinking of getting the 260 after reading all the comments and recommendations on this board I know it is the way to go eventually.
Please, please don't think I was maligning you guys cause again the information you have provided to me is invaluable, if that is the case, it was not my intent and I humbly apologise.
might lead us to misconstrue your meaning.. all is forgiven...Just wanted make certain you understand our motive, because "the difficult we do immediately ... the impossible just takes a little longer"...
There is a corresponding improvement in the sound of the 260 along with all the features, and if sound is everything to you the 4800 is amazing... but spendy. 8) but you would be far happier with the feature set of the 260, and just the ability to have an input PEQ of 9 bands and time alignment is worth the cost difference, and then we can add 10 additional PEQ's, completely separate paths through the unit so you have independent control of ALL features.
Actually with that high end rig of yours, you should have the 260, then you could use those Fr subs as mid bass speakers and REALLY pump out the jams...In fact I dare say you would have the benefit of PHAT sound like you could never get with system without them...Your upper register would be clearer, your low mids would really jump and you could time align all of it for better intelligibility and clarity...win win...
best regards
I will deffinitely look into getting a 260 in the next couple of months and add the 250 as low mids, I am just salivating at that thought
Thanks again for all your assistance.
JBL 2- PRX515 tops
4-Bull frog 18 subs 800 watts powered with 2 Crown CE-2000 bridged mono
subs are connected parallel in bridged mono in a pair per amp
I use this setup for many school dances as the new music has a lot of low end "grunt"
Previously I had been using Rane 2/3 way crossover at 100 hz and the system just plain got your attention with the low end thump but I had problems balancing the tops and subs outputs. Now the whole systems has flipped on me. I lost 3/4 of the bottom end but the PRX515's sound a whole lot louder than before.
I have run the auto setup for levels and EQ. I thought the sub synth would help but not even noticeable difference in bottom end thump.
