Driverack PA+ USB - a dummy?
edited August 2009 in PA General Discussion
Hi,
I just received my Driverack PA+. Seems to run fine. I did some setup with my 2 amped speakers (RCF Art 710A) and an amped sub. Maybe I should do it again with another Mike position, as the sound is not better than before... I have the original dbx Mike.
Afterwards, I plugged in an USB cable, expecting the 'New Hardware' to be recognized. But nothing happened at any USB port of my computer. Tried different cables with the same result. I also wondered, why the USB is nearly not mentioned in the manual and there is no CD included. Is that USB plug a fake or what is it for?
Any help would be nice. Thanks.
  • From what I know (not much), it is for updating firmware and wizard lists.
    I assume that there is no CD, because there has not been an update for the \"brand new\" firmware. I would not expect anything soon. The DRPA+ is more current than the 260.
  • Dra is correct.. at this time the port is there for updating only and is not developed fully yet, however it looks as though we may have a new project in the works for some additional external control of the 260 and perhaps a GUI for the DRPA+ so stay tuned...
    As for the Auto EQ... which preset did you use? A? B? C? or -0- flat? it makes a huge difference.. I recommend flat...and yes mic position will play a roll in the sound as well...
    Did you do the auto balance first? were any bands really cut or boosted? those are suspect...
    gadget
  • I just got my pa+ in today and was able to give it a run at an event tonight.
    One of the amps I use is a QSC PLX 3002, and it's not in the preset lists. Am I not able to add it to my pa+ with an update on the site?
  • Not yet as an update but why worry? Visit the QSC web site and get the input sensitivity ... but if your using subs it's a moot point anyway... use the gain structure to set the amp sensitivity is the best way... see the READ ME FIRST BEFORE POSTING section...
    http://www.dbxpro.com/forum/viewtopic.php?t=959
    And while your there peruse the FAQ section for whole lot of great info!
    http://www.dbxpro.com/forum/viewforum.php?f=60
