Rcf 725
After reading the manual and the gain structure of the powered speakers
i have to set the speaker level when i reach the cliping point.so in this case i have to understand that my speakers began to clip at 80 percent
so do ihave to change the level of the speaker on the DRPX panel to match the speaker level
and plesae another question what does the speaker level on the panel of DRPX do ,does it raise the volume or it is sort of limiting gain
No, as long as you have sufficient level on the DRPA your fine..
The DRPA output gains are just that...they change the gain... and if you ADD the limiters and/or the compressors they will affect the level as well..
