Crown XTI 2000/4000 Gain Structure
edited June 2009 in PA General Discussion
Hi Gents! The DriveRack PA I just picked up does not have the newer database in it for the XTI amps. Can someone please email me the setup? Running the 2000 in stereo into 8 ohms each main and running the 4000 into 2, 8 ohm subs bridged mono... Thanks in advance! taevans@everestkc.net
Need ASAP!
  • The Xti 1000 is the only one in the wizard I assume the others are the same input sensitivity? 55% is the setting on the new DRPA+... Oh and the 4000is 57% no bridging spec is available...
