Elite User :)
Hey gang,
It's been a long time since I last visited the forums. I actually just wanted some advise on an updated system I running now.
So here is the breakdown of my setup....
Speakers,
Tops - Yorkville Elite EX2000, 1000 watts, 4 Ohms (going to bi-amp)
Subs - Yorkville Elite SW1000, 1000 watts, 4 Ohms
Amps,
Hi - Yorkville AudioPro 3400, 4 Ohms @ 1200 Watts
Mid - QSC RMX 2450, 4 Ohms @750 Watts
Low - Yorkville AP4040, 4 Ohms @ 1200 Watts
Setup,
Looking to change from 2 way system to a 3 way system. I'm going to switch the Elite EX2000 into Bi-amp and would like to know your recommendations for the DRPA setup here. Any Advise would be great.
Thanks in advanced
Speakers,
Amps,
Setup,
Thanks in advanced
:roll:
Good question. It was recommend to do this as the QSC has a much clearer sound. I've tested both the QSC and the AP3400 in full range mode and there is a big difference in sound.. The mid sounds much clearer with the QSC. So I figured I'd put that as the mid and the AP on the Horn. If you think reversing it would be better, I have no problem changing them.
Wow I had heard the exact opposite... I trust however that the major players from the LIVE sound International Pro Sound web...They set up blind tests....They could not hear (for the most part) any real difference in the amps.
I WILL postulate that the amp being nearly double the output capability...that it could be driving the speaker into a MAX output situation, and in doing so... could QSC's lesser power be the issue? Either way I cannot believe there is a discernible difference...
It seemed to be a much "cleaner" sound. Not to sure how else to describe it. Mind you, could the age of the Amp have something to do with that too?? The AP is going on about 12-15 years and the QSC is about 3 years. Either way, I'm willing to switch as a test, but would like to know what I should set the x-over as for the 3 way.
Dennis
I can't find the tops listed by you...we need to have info on them to do that...
Looks like the newer models cross around 950-1000 in bi-amp mode.
EX2000 used a DE75 driver
2152 uses a DE750YT driver
Use this info wisely.
Ya trying to find any info on the tops is a miss for me too. I might have to take it apart to confirm but it's 2 15" and a horn. They are not located anywhere on yorkville's site or on any google search.
About the Internal x-over, I was told to rewire so that it gets bypassed and let the DRPA do the work. What do you guys think? Should I keep the internal x-over?
Thanks again for everyone's help. I'm still new to this thing too, even though I've had it for about 2 years...
PS - I suppose ypou could just eliminate the tweeter and let the horn go to the top, but you'll lose the very highest that the tweet could get to.
Dra?
You might want to go inside and see what components you have.. I guess form your post they do NOT have Bi-amp capability? Not very... Elite ...
DRa
As soon as I get home I'll update you guys on the drivers/horn type. But as for the bi-amp option, there is a switch at the back next to the 2 speakons to switch from full-range to bi-amp. More info to come...
P.S, Just want to extend my thanks to DRA and Gadget and the reset of the knowledgeable members. It's people like you that make this easier for the reset of us.. thanks again for all your time.
Is that the EXACT model #? not 2152, or 2204... (I have the Elite 2204's myself) they have the BMD750 driver and RCF woofers...
On the Tops (EX2000) - 2 15\" RCF - L15K80Y. Unable to see the Horn type
On the Bottoms (SW1000) 2 18\" RCF - L18Y800
If all this is true... I'd send the tops 100hz LR24 HPF, the lo-mid/Hf xover is then 1400 hz LR24 and the speaker should be allowed to go to OUT...Set the Sub @ 40hz BW18, and the LPf @ 100hz LR24...
Yes the Tops have a built-in crossover. So am I correct in saying, when I switch to bi-amp, that the 2 15's will be driven by the dbx mid outputs and the horn/tweet will be driven by the Hi output. Then the Lows out of the dbx go to the sub (2 18')..
If the above is the case, then your saying to setup the L @ 40hz BW 18, and LPF @100 LR24, the M @ 100hz LR24 HPF and the last setting H @ 1200hz <--- speaker should going to 'OUT' ? I'm sorry for the confusion on my part..
Thanks Gadget, So far so good.. Just need to adjust the eq's to get a little better sound and that should be it..
One last question. I was told to remove the built in x-cross from the tops. What would the benefit be in doing this if Bi-amp seems to disable it anyways. Or am I wrong in thinking it's getting disabled/bypassed. Could I actually get better sound without the built-in x-cross? Just picking your brain
IF the cab has a tweeter and horn requiring internal filters (and the cab panel does not say \"Tri-Ampable\"... CHECK
IF an amp could blow up right before or during a show, requiring running full range... CHECK
DON\"T PULL THE X-OVERS :!:
Great points. Thank you Sir.
But... I didn't see anything about a tweeter in the spec sheet provided...yes.. a diaphragm replacement for the DE75, but the next box is blank...no tweeter model listed? Did you see something different...
Yet there it is on his speakers...looks clearly like a bullet tweeter... :roll:
Those look to be the precursor to the Elite 2204's I have...Maybe the DE75's response wasn't sufficient? I couldn't find anything on a DE75... but the DE75PTN is 18khz??? For livesound over 18K is.. well hmmm :?
PS - Where'd I go?
It wouldn't matter that it was made in Toronto, Canada does it?
PS> DBX should pay for your internet connection cause if it wasn't for the two of you, this place would be going nowhere.
YA, it also doesn't matter UNLESS it isn't the DE75... that would change things...
Thanks for the cudo's...
