Drive Rack Pa and the Peavey Versarray
I need some advice as the guys on the peavey site are really telling me that I should use the VSX 26 over the drive rack PA. I know there are no presets for the versarray but I have set the Drive rack up to the specs I downloaded from their site.
I know it is in Peaveys best interest for me to buy a VSX and DBX to keep me as a user.
I need some comments or thoughts. THanks
Dennis
http://www.peavey.com/assets/literature ... 090_17.pdf
http://www.peavey.com/assets/literature ... 090_15.pdf
It has this data on it
Recommended active crossover frequency region and slope:
Sub –Low Frequency:
125 Hz at 24 dB/octave LR
Low Frequency – High Frequency:
2000 Hz at 24 dB/octave LR
Peavey uses a ribbon tweeter in the Versarray. The behaviour of a ribbon tweeter is perfect for a line array EXCEPT they are totally non-robust and most other manufacturers do not use them for that reason.
Dennis
I am a little confused but I currently am useing two DRPA's on either side of the stage to keep the speaker runs short. I manualy set it up to run the system with the specs I have given before.
The only thing I do based on some of the data from peavey is I run the subs at 100 and the mids at 95 to give a little over lap from top to bottom the tops are currently crossed at 2 k with the delay given.
GEQ -
1.6k -2.0db
2k -2.5db
X-over - L/M/H
34hz LR24 125hz LR24 gain +4db
100hz LR24 2000hz LR24 gain -0-db
3000hz BS24 out gain +7db
PEQ - L/M/H (filter widths are listed as \"Bandwidth\" and are probably portions of an octive. DR are listed as \"Q\", so you need to convert.
50hz .7 +4db, 100hz .5 -2.5db
560hz .5 +4db, 1200hz .5 +2db
2700hz .7 -3db, 4600hz 1 +3db, 16000hz 1 +3.5db
Limiter L/M/H
+9dbu 20:1
+6dbu 20:1
-1dbu 20:1
Delay L/M/H
0ms
.23ms
0ms
Hope this helps.
1 bandwidth = 1.4Q
.7 bandwidth = 2Q
.5 bandwidth = 2.9Q
Dennis
I own Advanced Auto and small engine...and specialize in computers and systems integration... fuel injection, electronic ignition, wiring systems. I repair anything.. \"I can fix anything but the crack of dawn\"...
I'm a fixer, and under the same roof I have an electronics LAB and repair facility I also build (-G-string- Guitars.. chuckle...) repair guitars, basses and instruments, as well as amps and what not (especially tube jobs, and I have some great tube amps.. I also have a speaker re-cone facility and build speakers for my own use... Upstairs is a performance space/recording studio...ya.. the place is jam packed :roll:
After all.. the one that dies with the most toys WINS!
Gary
Really? You have an overlap going on?
Dennis
The operation of it sucks plain and simple. Some engineer that is no longer with them bought a processor they never used before and its bad, really bad at least on the communications side.
I think being able to carry your settings on a USB stick could be handy. Time will tell
Remember, unless you have tons of system tuning experience, and the tools to do so, the FACTORY presets are the way to go...
Newer high end processor driven systems are more and going with locked out speaker setups that the USER cannot affect. this is done to take the user error out of the setup (xovers, delays, and PEQ's and sometimes alignment... when it's a \"system\") giving the user a \"tonal\" tweek and little more
The new DRPA+ is \"supposed\" to be able to (using the 'Wizard') set up a system \"optimally\" they even bought the speakers and amps they preset this time and actually (Jim Ure) DID the tunings...I am assured that the new Auto EQ will \"help eq the system to a room\" within 10-12 seconds...and it WILL sound better no matter where you place the mic...
I was able to do a A/B comparrison with two stacks of the line array and two amp racks. One the DBX and one with the VSX.
The point of all of this, I now have the two DRPA and a 260 in my monitor rack. I love the GUI interface with the 260
The VSX communiction issues are deep and most likely will not be fixed unless the make a change to it and maybe they will.
I was wondering if DBX would consider adding the besel xover and maybe adding the Peavey presets to their rigs,
I would love to be able to cmmunicate with the vsx and make changes real time but I am unable to as they live on stage at this time.
Now if I change to a drive line and install it at the FOH location this issue MAY go away.
I would love to see the guy on the 260 page write a software that would allow me to see/speak to multipul units with out jumpiing through hoops,.
