delay parameter
I can't get the data wheel to change the delay in output 5 in the post crossover eq. (I'm running the subs mono from this output.) I push it \"on\", and push it to \"fine\" not coarse, and I push my units to seconds, not feet. When I try to adjust the 0.00 to something else with the data wheel, nothing happens. The sound guy we used last year struggled with this too, and said something about this module not having been installed at the factory, but he did get it \"installed\" or otherwise working.
Well, now i've gone and done it--I saved over his settings, and i can't get the data wheel to move that 0.00 at all. All i really want is .92 ms of delay on the subs. Interestingly, when I hook up this laptop with the driveware software, the two post cx \"D\"'s representing the post cx delay modules are in red, not white like the rest, and they will not open when I double click, unlike the rest of the modules which I can program pretty readily.
I didn't think something like a .92 ms delay on the subs would make a difference, but I could hear it, it make the srx 718s and the 722 top boxes sound like they were all one hi-fi stereo speaker.
Help !
much obliged,
rickrock
Help !
much obliged,
rickrock
Left click \"Config\".
Right click on a \"Red D\".
A drop down menu will appear.
Select an adequate maximum amount of delay for that output. (eg 100ms)
Repeat with other \"Red D's\".
Left click \"Yes\"
Double left click on one of the output delays you just reconfigured.
Set delay as necessary (eg .92 ms).
Repeat if necessary.
Dennis
rickrock
Dennis
But as I am trying to get back to a setting someone else put in, (which I liked), I have to confess, I'm not certain which of the modules he had the delay put in. I'm remembering he told me he wanted to delay the subs a bit, and the pre-cx delay is does not pinpoint the subs, if I am getting it.
Is there are rules of thumb here, or a 'best practice' that says when fine tuning a jbl srx system, you want a little delay on the subs in the post CX module? That would help give me a little confidence anyway,
much obliged
rickrock
So i do have the output 5 at .92 ms of delay, so the subs will be delayed that much. Does that strike anyone as just wrong, (ooh, that's just wrong...)? I'm pretty sure that's where it was.
much obliged
rickrock
.92ms may or may not be correct. Without running the tests, I wouldn't know.
Dennis
I delay my lo mids to my LABsubs about 18.5 ms which is understandable since the labs are about 10.5 feet of horn length... and then there's the propagation delay...and ????
your mileage may vary...what sounds right ultimately IS! Let your ears be the judge!
You're right, it is a function of what sounds right, and that little bit of delay did the trick last summer (we tend to get the big rig out for the summer outside gigs). The guy we had help us last year said he had a few tricks up his sleeve from talking to jbl guys--one of which was this slight delay in the subs. Another was a PEQ setting, where he ratcheted down maybe 2dB of 658 hz in both the highs and the mids--same setting to both even though the highs were crossed at somewhere around 1.16k. He said this was a jbl engineer recommended 'trick' that is not in the PEQ presets for the srx 722's, as was the .92 ms delay. Little improvements that made a big diff in the sound.
You guys are a great help, and it's great to have you here. Next project, buying a second 260, a second sub amp and splitting my amp stacks right and left. This is as much a way to help our aging backs as anything else.
much obliged
rickrock
Dennis
The first 260 would receive the \"left\" input, and send out hi mid and lo to the amps in that rack, and the second 260 would get the \"right\" input and do the same in that rack. With that configuration, we have one cable coming from FOH to the left and one to the right, each with its own 260 and amp rack. Otherwise, you have two cables going to one amp rack, with the 260, and three xlr cables (high, mid and low) across the front of the stage to the other amp rack (or with mono'd subs, only two, with the speaker cable for the subs going across for the lows).
Yeah, cables are cheaper than a 260, but don't you lose something in that cable run, say 30 feet from the 260 to the other side of the stage's amp rack? Anyway, this is what I've heard some of the rental houses do with their small to mid size rigs. I'm always learning here, which is why I mentioned it, so take aim and fire.
The signal loss is infinitesimal. Run the cables to the other side. If you plan on controlling the (2) 260's from FOH with the GUI.... think again. Can't do it. One at a time only. Sorry.
Dennis
FOH:
Pro's -
If it locks up for some reason, you can power it down without running to the stage. (That's a pro? :roll: )
Access Auto-EQ. (You don't want to have to go to the stage during a show to use it. :shock:
Con's -
Depending on set-up, may take up too many snake returns. (Stereo 3-way needs 6)
Unlabled patching can cause problems and damage.
Amp rack:
Pro's -
Amps can remain patched.
For the most complex set-up a maximum of 3 snake returns are needed. (including GUI control line)
Con's -
GUI is \"mandatory\" for any control at all.
GUI special cables for snake use must be made.
If it locks up for some reason, you can't power it down without running to the stage.
You have to go to the stage to use Auto-EQ.
There is no right or wrong. Only what fits your needs.
Dennis
We'll never get to the point of putting the 260 anywhere but in the amp rack, because it doesn't get used on the fly. We just need the speaker PEQ tunings, crossover, RTA auto eq room pinking, AFS, and that little delay we were discussing, so my crowns and jbl's work together well. We're weekend warriors, playing fundraisers and country club gigs to crowds of 200-400 for the most part. But we do get compliments on our sound. So now I'm trying to get both sound and logistics working together, and two lighter amp racks seems better than one heavy one. There is also the fantasy that with two racks, each tricked out with lo mid and hi amps and a processing unit, I'd have the making of small rental co, and could use both or either as needed. (I also happen to have 2 10 space racks not otherwise being used right now--except as spacers between the 718 and 722 on each side.)
Anyway, you guys are invaluable as usual. Thanks for the help.
rickrock
