Configuring the DR260
Hi
I am just playing with the setup on a DR260 using the driveware. Maybe someone can answer these questions;
If I unlink stereo inserts etc. how do I link them back up again?
How do I configure the matrix? At moment all I appear to do is be able to select a standard setup with a matrix config that is almost what I want, then start from there?
Best wishes
Jon
Best wishes
Jon
Jon, go to the \"Driverack Training Modules\" section above and do the 260 tutorial. It will really help you \"see\" how to do that and more.
Thanks for that, I will try the training!!!!
For anyone else's info, I sussed out the linking, you click on the first module, then hold down the ctrl key and you can select the 2nd module, then right click and you can link!
Best wishes
Jon
