Speaker levels on PX
Hi, guys!
I tried to find the answer from the user manual and this forum, but I couldn't find one.
If I want to adjust my overall speaker levels on OUT and SUB manually, how do I do it?
I know that the wizard is auto-balancing the speakers when I pink the venue, but what about the manual adjustments after the wizard is complete? I found out that the Filters-module has a gain (-INF to +20dB) control for both bands but is the only way to control the OUT and SUB levels manually?
Thank you!
//rgds Juza
Edit: syntax error
Thank you!
//rgds Juza
Edit: syntax error
So, in a nut shell, the x-over filters are used to raise / lower the bands separately.
