Gain help for 260
I have read the \"gain structure\" described in the read me first section but have some questions since my system is a bit different.
I am using the 260 in a consumer system were the preamp is RCA to XLR which I assume has lower gain. My amplifiers have a fixed gain with no attenuation adjustment.
The 260 gain jumpers(inside the unit) are default.
When connected if I adjust the input level to get the meters in the yellow with my preamp gain set near max volume I have too much gain out of the 260 such that my music volume is too high(amps appear to be too sensitive). To counter this I adjusted crossover gains down to near min and I want to confirm this is the proper adjustment or am I missing something. This of course sets my output meters to a point where they just barely flicker(2leds) near max output.
Any help is appreciated
  • OK. The setting of the gain structure is to assure that you don't clip the amps AND to set all components (before the amps to make thing simple) to be at -0- at the same time. Once you do this, the mixing console's master volume should be reduced to produce the volume you seek.
    So.... with amps disconnected (or off)
    mixer - at clip
    driverack input and output meters @ +16db (that's 6db headroom in the DR).
    Use mixer output to control volume.
