Gain structure questions not covered in read me or FAQ's
Okay, I've posted here before on the system I am using at a church. I understand the basics of setting the gain structure. The problem: The speaker being used is a powered unit and, cannot disconnect speakers from amp without disassembly, and second, setting the gain to the level of clipping, would be way to loud for the room. I have done a little better by getting the relationship between the mixing console and the DRPA so that I'm getting better results from compression, limiting, etc.. The gain on the speaker-amp is down almost to the point of dropping out all together. I'm also wondering if this is having an effect on the sound. Would using an attenuator between the DRPA and the speaker-amp help?
Equipment:
Ramsa 4416
DRPA
Samson powered amp (Yeah, I know, Iknow, but it's what I can afford)
I should note that it's divided to 50 amps for highs, and 150 for lows, and has single input to onboard crossover.
I know I could do much better, but they actually don't sound too bad, and I don't do very much of the sound work - nothing outside the church stuff. If I were in to this for money, it would be different.
Equipment:
Ramsa 4416
DRPA
try turning the speakers so they crossfire to avoid the back wall and see what happens (as a test) comb filtering will be worse but...
Try this...
http://www.mcsquared.com/reverb.htm
play the various files and see if they match up with what your experiencing.
A lav...with speakers BEHIND the speaker...YUCK... sounds like a recipe for disaster...
Those speakers should be center clustered and aimed down on the congregation...so the sound gets on the people and off the hard surfaces...if that isn't possible... treat the back wall if possible...
Didi you listen to the links I sent? and what is your thought there?
This is a wide shot of the sanctuary. In this picture, you can see the relative position of the pastor to the speaker during the \"joys and concerns\" (at the candles).
This shows both the eyes into the beams, and the back of the column speaker. The eyes are ~ 11' apart which would put each eye ~ 5.5' off center. Picture taken from the altar area.
This is a little closer shot of the altar/stage area. If you look at the \"corner\" where the upper level (top step) is, it is approximately the position of the eye in the beam above. These beams are ~ 3' forward of the stage/altar area.
So far as the samples go, nothing really fit what I have heard from time to time. What I've heard is only a single repeat a fraction of a second later. I'm wondering if the compression, or limiting has something to do with it. I shut off the comp and limiter yesterday and did okay, but what I found interesting was the change in the pastor's voice (through the system) and found that I needed to make changes on the channel EQ for his mic. Shure receiver (not sure which model) with WL 185 mic.
I was under the impression that I needed to use compression to compensate for the changes in the relative position of his mouth to the mic, and limiting as a way to insure no feedback beyond the AFS (levels just too plain high). Two questions, will the adjusting of the gain at the xover have an effect on the EQ, or anything else? I did a little experimenting yesterday and went even further down with the gain for the pastor, and brought it up for the youth choir (not as strong, and further from the mics). Second is whether that 5.5' off center for the speaker will have a noticeably negative effect on the sound? It can't be any worse than the other speaker where it is, which is somewhere about twice the distance off center.
BTW Gadget, I love your avatar, but it's a little sadistic isn't it?
I will have to get back with this later...
As for the avatar.. I get frustrated sometimes... 8) what can I say...
Your overhead hang points should be machine threaded eyebolts that go through the entire beam and have nuts on each side of the beam. The eyebolts must have an adequate advertised weight rating with at least a 5:1 load factor. It would be even better if you hired professional riggers to install your overhead hang points. They are expensive but much cheaper than a lawsuit.
Your speakers must have flypoints on them. DO NOT HANG THEM FROM THE HANDELS. If they don't have flypoints, you will have to install some. Check out ATM Flyware for rigging solutions: http://www.atm-fly-ware.com/
It is unsafe to try to rig speakers at 14' to 20' without a scissor lift or some form of personnel lift. Rent one for one day. It's less expensive than a hospital visit.
Dennis
The bottom line is that the powers that be within the church see what I'm doing more as \"icing on the cake\" rather than something that's really needed. Along with that, we are a church that is struggling to survive in several ways. While safety is of the utmost importance, money is tight both for the church and myself, so my options are limited.
Now, with that aside, as a possible option, I have tried using the house system by feeding a signal to the house amp and bypassing the EQ on the unit. The sound wasn't all that great with the column. Fine for speech, but lousy for music.What are the chances that I could get better sound off of the column by driving the column directly from another amp. The house amp is a 35 watt Rauland Borg. The other amp is a GLI 100 watt/channel 2 channel amp. The problem is that the speaker is hooked up to the 16 ohm connections on the RB amp. I'm not sure how the GLI will handle the double impedance
We can come up with ways to cheat when you are wiring up electronic equipment so you might use a wye cable or some other widget to make a piece of gear do something other than what it was primarily designed for but no one on this forum is going to endorse substandard rigging practices. It could come back and bite us.
Dennis
So now, how about the other questions? The house system has a Rouland-Borg amp in it (35w) plus the column speaker shown in the pics. I have tried already feeding a line level signal from the DRPA to the Aux input using a matching transformer to go from balanced to unbalanced. With the EQ on the R-B bypassed, the sound coming from my system sounded a little better, but not much. The first question involving this is whether there is likely to be any improvement in the overall sound, if I just disconnect the speaker and drive that from a GLI 100/channel amp? I suspect that the bottom line is that it's not a question of what amp, but but the speaker column itself. I'd just like to confirm that if possible. As I said before, the house system is great for speech, and is nice and clear, but not for music as it's missing upper and lower frequencies. Am I correct that it's okay to run a higher load (impedance), but not a lower one unless the amp is designed for it?
To the question on the DRPA. I've found that I can solve (at least in part) the problem of running the amp at such a low level (almost to the point of cutting out. I'm doing this by dropping the signal at the xover. This was a suggestion made earlier to get a less audible response when running AFS. If I change that level after running EQ and AFS, will it affect either?
Well... the column speaker is a \"fullrange\" cone only speaker that is DESIGNED for speech only...why not take that down and put a REAL speaker where it was..although sending the sound through those chopper blades is a real NO NO...as for the 35 watt amp... are you kidding? speech only, nothing more through that...you would need a speaker of 90 degrees in that position though... how about one that has a vertical pattern that coupled with the horizontal covers the people and not the spaces...? maybe move it back one column to avoid the fan and make sure the vertical pattern is over the head of the raised stage area...Hey, you have a beam... you can make t work, it's just a matter of making sure its safe...
What is the coverage pattern of that speaker you want to fly? USUALLY in a church of that size we would spec 2 speakers with 60X40 patterns for a 120 degree horizontal, or with a rotatable horn for 80 degrees horizontal and 60 vertical.. this helps keep the sound OFF the walls and ceiling, and on the public... If you have the speakers too far toward the audience/congregation, you will miss the first few rows...
Do I want to know what UFDA means? Does it end with \"Ass\"?
