Need some help regarding the speaker conectivity
Hello, i need some help setting up a new club sound system, and I've got the dbx pa at my disposal, problem is i cant figure out how to connect it to my particular setup.
The system won't be used for live events, it will be used mainly for dj-ing, therefore the sound should come from mixer>dbx pa>amps.
Here is the complete setup:
4 front speakers, 2x left and 2x right
2 front subs, left and right
2 back speakers, left and right
Front speakers will be powered by 2 amps, subwoofers will be powered by 1 amp and another amp for the back speakers.
-Mihai
-Mihai
Dennis
Amps:
3x Install 2000 for the front & back speakers with the following specs :
Install 2000
Stereo Power (8Ω) 2 x 350W
Stereo Power (4Ω) 2 x 560W
Stereo Power (2Ω) 2 x 720W
Bridged Mono Power (8Ω) 1120W
Bridged Mono Power (4Ω) 1440W
Frequency response 20Hz - 25 kHz
THD + N 0.05%
Signal Noice Ratio >100dB
Damping Factor >300/8Ω
Input Impedance
20kΩ (balanced)
10kΩ (unbalanced)
Input Sensitivity 0.775Vrms
Input Connectors Balanced to ground, XLR, TRS
Output Connectors Speacon + Output binding posts
1x Install 3000 for the subs, with the following specs:
Install 3000
Stereo Power (8Ω) 2 x 700W
Stereo Power (4Ω) 2 x 1100W
Stereo Power (2Ω) 2 x 1500W
Bridged Power (8Ω) 2200W
Bridged Power (4Ω) 3000W
THD + N 0.05%
Input Impedance
20kΩ (balanced)
10kΩ (unbalanced)
Front speakers are 15\" woofer,2-way,500W / 8 ohm, full range
Back Speakers are 12\" woofer,2-way,500W / 8 ohm, full range
Subs: 2x 1x18\" Subwoofer, 5\" voicecoil 700W RMS
All components are manufactured by lraudio.fi(in case im missing something and you might wanna check it out), including amps.
As i am pretty bad at drawing, the distance between the front speakers and the back speakers is ~ 20 meters.
PS: thanks for the quick replyes, ill try and draw the diagram for the club later today.
Dennis
Dennis
I will be using a bigger version of the Club 12 model, and respectively a smaller version of the fronts, for the back.
And yes, that is my main setup, i considered that the biggest SPL should come from the front, that's why i opted for a 4 speaker setup and 2 woofers for the front.I was thinking that should be enough for the room.
Dra, i cannot cluster them, i've thought of that, but the front speakers will be hanging from the ceiling, aimed at the center of the room, as the back speakers.
So with this explained, do i have any chance of using the dbx pa, or do i need another dsp ?
but... set up a 2x5 or 2x6 setup (stereo)(5 is mono subs) all custom in the wizard and run the front tops off the hi outs the back 12's on the mid outs and the and the subs off the lo outs (mono left for bridged subs)
Set up the HPF @ 40hz BW18 and LPF @ about 120hz LR24... that's the subs
Set the HPF for the front and rear speakers @ about 120hz LR24 .. If you can put the subs in the center but together for sure to take advantage of the free 3db coupling.. bridge the sub amp and run he subs parallel...If you splay the front tops to avoid crossing coverage on the ones right next to each other you will suffer far less interaction...
If you just must have two speakers per side at the front, you might want to rotate the horns. They are 50*x80* and you might want to rotate them so they are 50* horizontal and 80* vertical although this might create a completely different mess.
It looks like the install 2000 is underpowered for your set up. How do you plan to wire up all of your speaker/amp combinations?
You have said the length of your coverage area is 20 meters. What is the width of the coverage area?
Dennis
I will be coupling the front speakers 2 on each side, and i will try to couple the subs in the middle.
Is there any suggestion for the back speakers ?, i'm well aware of the chaos you're talking about, its exactly how it sounds right now.I thought that the major couse of this was the speakers themselves, which right now are DIY models.
@Dennis
Width is ~15 meters.
The Install 2000 will run in mono, one for each front side, and one for the back, for which i'll get 4x2.5mm2 cables.
Mihai
Oh and as for the back speakers only run them as loud as needed to meet the sound coming from the front...
Since we're still at it, if you've got some free time, can you check out the website, and make a system that you think should fit great in the room i've mentioned of.
I'm planning to order the products on Tuesday, so i've still got time to order anything i want.
Current speaker system is formed from some Dynacords and some no-names.
Website is www.lraudio.fi.
Thanks, M.
http://translate.google.com/translate?h ... 26hs%3DbZl
I will couple the fronts 2 by 2 , with one next to each other, left and right.I will also have to tilt them forward so the horn will aim at the center of the dance floor. And i was thinking to use the subs in stereo, so it should go 2x 6 on the DSP.
One more thing, how high should the horn be from the ear of the listener ?Can i put them as close as i can to the ceiling and just tilt them towards middle ?
i've just finished setting up the whole system, but there is a problem,
i hear only mids from back tops and only highs from front tops.
i've connected the front to the hi outs
mids are back
subs are left/mono
setup is 2x5 with bi-amp speakers, if i try to use passive it switches to 2x3 and i get no signal on mid outs.
any suggestions are welcomed.
Mihai.
[ 20hz /-------20khz]
should look more like this:
[ 20hz /----------------------------------------------20khz]
now the slope indicates the LR24 and the line should be solid and meet the slope line but hopefully you get the idea.. I don't have a lot of time right now...
do the same for the Mid xover...
Many many thanks for the help ! 8)
